Results 1 to 2 of 2
Thread: Delta Three-Handled Faucet
    DIY Junior Member stavner's Avatar
    Oct 2010
    Tennessee
    Default Delta Three-Handled Faucet
    We have a Delta three-handled faucet in our bathtub. The hot water handle was leaking, so I went to Lowe's and got a 7S-4D diverter stem extension, a diverter stem, and some seats and springs, all Danco brand. I tried putting the seats and springs in in all the combinations--seat first, then spring, spring and seat, small end of spring in seat--but no matter how I turn the handles, water still gushes out of the spout! What am I doing wrong?
    How should I put the seat and spring together?
    Is there something in the metal pipes the handles go in that I should remove with a socket wrench? In the hot water pipe, it feels like there are two holes for the spring, and the hole in the cold pipe feels like it's off center!
    Plumber jimbo's Avatar
    In the tree handle valve, there should be one seat and spring each, on hot and cold. The hole should be off center, to match te off-center hole or slot on bottom of stem.
    If the springs which came out were short and stubby, use that type. Larger end of spring down into the valve.
    If you valve is older, about 1972 date or older, it may use a long thin non-tapered spring.
  1. Inspector wants full backflow preventer discharge handled by sanitary?
    By jobujobu in forum UPC Plumbing Code Questions
    Last Post: 09-21-2010, 11:25 AM
  2. Delta 600 Shower Faucet
    By Bkster in forum Shower & bathtub Forum & Blog
    Last Post: 04-02-2009, 08:24 AM
  3. Help with Moen Monticello single handled
    By dayton5959 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2008, 07:22 PM
  4. Old Delta Faucet
    By scm23 in forum Shower & bathtub Forum & Blog
    Last Post: 11-17-2008, 06:08 AM
  5. Delta tub faucet
    By wshful in forum Shower & bathtub Forum & Blog
    Last Post: 12-31-2006, 07:42 AM
