Results 1 to 6 of 6
Thread: copper pipes pressure vs leaks
    DIY Junior Member darque's Avatar
    Oct 2010
    orange county california
    Default copper pipes pressure vs leaks
    do copper pipes leak at the one weakest link "only" or can they leak at multiple places at the same time? my question relates to a concern about fixing a small leak at the water heater connection that is not that big of a deal knowing a little corrosion will eventually block the leak vs fixing it and discovering it leaks worse in the attic?
    currently, it does not leak in the attic. so, my assumption is if i fix the leak at the water heater it should for the time being not leak elsewhere? is that thought process accurate or is anything possible with pressure
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Fix it, if another leak happens, fix it. Corrosion doesn't fix leaks!
    Copper pipe, properly installed, can withstand far greater pressure than you'd ever see in a home. Now, depending on your water chemistry, it can literally eat holes in it. Incorrect installation can cause premature erosion of the pipes downstream from say a joint where the pipe was not properly prepared. So, unless you have agressive water, or there were other installation errors, one leak at the WH, is not an indication of impending problems elsewhere. Now, if your neighbors all are having pipe failures, then that is another story! SOmething to look into.
    Oct 2010
    ok ok thanks guys..... fix it i will
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by darque View Post
    This is statistically unsound reasoning, I think. It's definitely in violation of Murphy's Law.
    Maybe somebody pressure tests residential pipes in place to ensure there is still a safety factor over and above the normal pressure it has to withstand. Hopefully the test would not speed up the failure of an already marginal pipe wall.
    We had a rash of pinhole leak failures several years ago so the WaCo put orthophosphate in the water.
    There are devices that will detect water running/leaking and will either alarm and/or shut off the supply.
    Copper joints leak because they were NOT done properly in the first place, or there is a water/erosion factor causing them to go bad. If there are more than one bad joint, they could ALL fail eventually, or NONE of them may. It depends on how bad the joint is. If it is a functional problem then it could happen anywhere at any time.
  1. Copper Steam Pipe Leaks
    By Frank Dalessio in forum Plumbing Forum Discussion & Blog
    Last Post: 07-30-2009, 02:00 PM
  2. Anyone ever seen pinhole leaks in the HOT pipes?
    By AcidWater in forum Plumbing Forum Discussion & Blog
    Last Post: 11-23-2008, 04:45 PM
  3. Copper Piping Leaks-What Causes?
    By Texas Zorro in forum Plumbing Forum Discussion & Blog
    Last Post: 08-10-2007, 09:03 AM
  4. Leaks in our hot water recirculation pipes
    By luc in forum Plumbing Forum Discussion & Blog
    Last Post: 04-30-2007, 03:16 PM
  5. leaks in shower and tub pvc pipes
    By caugie in forum Plumbing Forum Discussion & Blog
    Last Post: 12-07-2006, 12:35 PM
