Thread: Sharkbite
    DIY Junior Member vlee1973's Avatar
    Oct 2010
    Wisconsin
    Default Sharkbite
    What happens when you don't remove the sleeve when attaching the sharkbite to cooper? I'm asking because I did it.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Nothing its just easy to install without one in.
    DIY Junior Member bobur7's Avatar
    Jan 2013
    Mesa, AZ
    Per the Sarkbit website "The SharkBite® fittings have an integral Tube Support Insert that is effective in supporting PEX tubing to ensure the O-ring seals correctly on the outside of the PEX tubing. The Tube Support Insert is not required when using CPVC and copper tubing; however it is not necessary to remove the insert when using these materials."
  1. Sharkbite vs Gatorbite
    By miamicanes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2013, 07:13 AM
  2. Sharkbite VS Soldering
    By Kiko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2010, 11:14 AM
  3. SharkBite fittings
    By PEW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2009, 08:11 AM
  4. Sharkbite fittings?
    By smhowell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2007, 04:41 PM
  5. Sharkbite/pex problem
    By dsmarian1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-17-2007, 07:13 AM
