Results 1 to 5 of 5
Thread: bad ground & electricity charges?
    DIY Junior Member darque's Avatar
    Oct 2010
    orange county california
    Default bad ground & electricity charges?
    could electricity "leak" in a home through badly ground pipes copper or other metal (?)
    hypothetical~ if my copper pipes were not grounded properly causing corrosion to the water heater would that in any way use more electricity increasing the monthly kilowatt usage?
    just wondering.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by darque View Post
    just wondering.
    Galvanic corrosion uses DC. Your elec. meter does/should not respond to DC.
    Even if it did the corrosion is caused by a DC current loop that doesn't add or subtract from your household AC usage.
    But, in principle, you could test this.
    DIY Junior Member zorka's Avatar
    Oct 2010
    Canada
    No, electricty would not leak in the way that you described (i.e. on a continuous basis).
    If it did you would be in danger of electrocution EVERY time you touched a faucet or metal sink. I was testing a customer's system one time with a "TicTracer" which responded to electrical currents. When I went past their refrigerator, it "lit up". The reefer housing was "live" and the only thing that prevented them from shocks was that there was no plumbing nearby that they could touch at the same time they were at the refrigerator.
    Oct 2010
    ok great thank you.
  1. Outrageous furnace repair charges
    By bobbobwhite in forum HVAC Heating & Cooling
    Last Post: 03-02-2010, 11:57 AM
  2. Buying electricity from a neighbor....issues?
    By Schrammdriller in forum Electrical Forum discussion & Blog
    Last Post: 04-13-2008, 03:51 AM
  3. Repair charges?
    By steve317 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-10-2008, 06:27 AM
  4. Electricity is out in a bathroom
    By milik in forum Electrical Forum discussion & Blog
    Last Post: 12-28-2007, 02:28 PM
  5. plumbing charges
    By markmark in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2007, 06:07 AM
