Results 1 to 6 of 6
Thread: Question: D3309 Grey Pipe, is it safe?
    DIY Junior Member Orcacalling's Avatar
    Oct 2010
    Alert Bay, BC
    Angry Question: D3309 Grey Pipe, is it safe?
    I am trying hard to find out if this kind of pipe is safe. It has been withdrawn, yet my apartment is using it for hot and cold water. I think it is breaking down. We do not have chlorine in our village well water.
    Robin
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    It's polybutylene pipe. No if ands or buts about it. Zurn, owner of the Qest brand, does make QestPex pipe, but the PB2110 identifies it as polybutylene. Now that that is cleared up.
    Read Terry's Post at "http://www.terrylove.com/qest.htm
    Kevin
    Plumber jimbo's Avatar
    I seem to recall that the issues with PB were two: one had to to with the fittings, but then long term there is a problem with pinholes, but that was related to chlorinated water, so you should not have a problem.
    Dec 2007
    Jimbo you are right! The initial problem was with the actal fittings but later the tubing itself was breaking down from chlorine content of the water supply.
    If you are on a well (non-chlorinated) and you haven't had problems, why fix it if its not broke?
    Oct 2010
    Alert Bay, BC
    Thanks for replying. We took off the tap fittings in kitchen, and bathroom and flushed the water through. About an hour later I could not smell or taste metalic anymore. A floral smell was in water instead.hmmm. Test results come in soon. Thank you Robin
    Quote Originally Posted by Redwood View Post
    Oct 2010
    Alert Bay, BC
    Default Thank you Jimbo
    Thanks for commenting
  1. Question about a slip fit type plumbing connection, are they safe?
    By jonjonbear in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-17-2010, 07:11 AM
  2. is it safe - light switch question
    By beekerc in forum Electrical Forum discussion & Blog
    Last Post: 10-27-2008, 04:30 PM
  3. Orangeburg pipe safe to snake?
    By Joe R in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-11-2007, 02:32 PM
  4. Affordable Safe Step question
    By Jack Matthews in forum Shower & bathtub Forum & Blog
    Last Post: 03-25-2007, 09:55 AM
  5. Old Baseboard grey pipe/alu fins?
    By jhetzig in forum Remodel Forum & Blog
    Last Post: 03-14-2006, 07:07 AM
