Results 1 to 4 of 4
Thread: Section 305.6 Freezing
    Default Section 305.6 Freezing
    Inspector tells me that all waste lines installed in an open parking garage need insulation & heat trace. We only traced the exposed traps from bathrooms above. Is this correct? I never heard of insulated drains in a parking garage.
    Retired prof. engr. gator37's Avatar
    Nov 2009
    Alabama
    Sounds a little flakey to require insulation downstream or the traps.
    Jun 2009
    Canada
    Interesting.
    At least he didn't say they required only insulation. Insulation would be useless without heat tracing.
    Yakima WA
    A properly laid drain should never have standing water in it, so insulating doesn't make sense to me.
  1. Removing PVC threaded section from cast iron
    By Indy_Keith in forum Plumbing Forum Discussion & Blog
    Last Post: 04-30-2010, 07:21 PM
  2. repairing a section of cpcv pipe
    By huliman in forum Plumbing Forum Discussion & Blog
    Last Post: 01-08-2010, 06:11 AM
  3. Replacing section of sewer pipe
    By Lakee911 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-26-2008, 11:46 AM
  4. 3/4 supply.....1/2 section.....3/4 run....
    By nbahm in forum Plumbing Forum Discussion & Blog
    Last Post: 03-06-2007, 08:26 AM
  5. Cleanouts for Horizontial Vent Section?
    By chuyser in forum Plumbing Forum Discussion & Blog
    Last Post: 08-28-2005, 06:00 PM
