Thread: Question about setting tub in mortar bed
    DIY Senior Member BimmerRacer's Avatar
    Jan 2009
    Washington, DC
    Default Question about setting tub in mortar bed
    When packing the mud prior to dropping the tub in, how much of the mud should be packed and how much should be loose? I suspect while the mud consistency is the same as the shower dry pack, it need to have some give to accomodate the tub bottom inperfections and leveling.
    What's the procedure here?
    Jan 2009
    Washington, DC
    NM, I found the thread with the "piles" method described. I even posted in it
    When I do it, which is seldom, I use bags of perfatape cement. I slit the bags so air can get in to harden it, then flatten the bags somewhat and set the tub onto them. THis way the cement cannot flow away, nor can it adhere to the tub's bottom.
  1. Setting water pressure question
    By djryval in forum Plumbing Forum Discussion & Blog
    Last Post: 02-01-2010, 09:44 AM
  2. aquastat setting and boiler question
    By bbillcee in forum Boiler Forum
    Last Post: 10-12-2009, 05:37 PM
  3. Mortar bed Question
    By tk0517 in forum Shower & bathtub Forum & Blog
    Last Post: 08-11-2009, 09:45 AM
  4. Pressure Switch Setting Question
    By Marc46 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-18-2008, 07:14 AM
  5. Mortar under tub question
    By Randyj in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 07:21 PM
