Results 1 to 8 of 8
Thread: Design, connecting shower and washing machine drain to the same sewer pipe.
Hybrid View
    DIY Junior Member Florin's Avatar
    Oct 2010
    Montreal, Canada
    Default Design, connecting shower and washing machine drain to the same sewer pipe.
    Name:  basement plumbing1.jpg
Size:  28.2 KBName:  basement plumbing2.jpg
    Hello,
    Design brainstorming, connecting shower and washing machine drain to the same sewer pipe.
    My wife asked me to move the washing machine and dryer in the basement. The house is built in 2005 and the basement is not finished.
    I attached 2 sketches of what it looks like. Things in black exist already, things in green I plan to install, to make my wife happy .
    The builder left an opening in the cement slab where I can see the end of the exiting horizontal drain pipe. It’s 2 inch in dia. and has a plastic cap on it. I cannot be sure where the other end of this plastic pipe goes but judging by the angle it must come from the same vertical drain as the future sink.
    As I showed in the first sketch, I’m planning on adding a p-trap to the shower and one to the washing machine (inside the wall, at the back of the shower cabin), then I would go horizontally north and merge the 2 drain pipes somewhere before connecting to the existing drain.
    I actually prefer the second sketch. This would ease the installation because I would not need to break too much from the cement slab to pass the pipes. In the second design I connect the washing machine drain pipe to that of the shower using a T so that to avoid using two parallel pipes.
    All pipes are 2 inch dia.
    My question:
    Would both these designs work properly? What can I do to make sure the water from the washing machine does not go up in the shower?
    Jun 2009
    Canada
    You've got a lot more learning to do before you take this on.
    Have you ever seen a fitting like this before?
    What is the plan with the toilet?
    All of your drains require vents...
    Oct 2010
    Montreal, Canada
    dlarrivee, I'm sorry for not mentioning this, but the builder said he already installed the vents and drain for sink and the toilet. He also left the opening for draining the shower. I only have to connect it.
    Dec 2007
    I see the shower drain becoming a geyser...
    Oct 2010
    Montreal, Canada
    Quote Originally Posted by Redwood View Post
    No, no, the shower is not installed. All the green items in the sketch are future. I just need to make sure the design is correct.
    Thank you for your help.
    You CAN"T run the drain line right under the shower opening and still install a "P" trap properly. The horizontal 2" line will create enough resistance, that the washing machine water will probably back up into the shower, unless the horizontal line is at least 18"-24" below the floor. Plumbing codes, and good practices, do not allow the washing machine to connect ahead of a floor drain or shower anyway. It is called "a major fixture over a minor one". Depending on the toilet opening's dimension from the two sides you may be in the market for an Eljer "Triangle" toilet to fit into the corner.
  1. Why are soap suds coming up out of my washing machine drain pipe?
    By red13 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-11-2012, 05:26 PM
  2. Replies: 7
    Last Post: 08-21-2010, 12:30 PM
  3. Main drain pipe clogged after washing machine
    By Tom W. in forum Plumbing Forum Discussion & Blog
    Last Post: 06-26-2010, 10:00 PM
  4. Sewer Gas Coming From Washing Machine Drain Pipe
    By jax in forum Plumbing Forum Discussion & Blog
    Last Post: 02-11-2007, 09:31 AM
  5. Sewer Gas at Washing machine
    By Tanias55 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-24-2005, 01:26 AM
