Thread: bathtub faucet turns on by itself
    DIY Junior Member sproksch's Avatar
    Apr 2010
    Virginia
    Question bathtub faucet turns on by itself
    Hello!
    I had a stem leak on the hot water stem of my American Standard bathtub valve. So I replaced the stem (and stem seat) with a brand new one (part 9C-23H/C), but the stem leak was still there. I took the stem out and put it back in a few times trying to figure out what the problem was. But now the stem leak is the least of my problems because now I canít get the hot water to stay off Ė when I close the valve and let go of the knob, the knob turns itself back on like its spring-loaded or something. I really donít know what to do Ė everything on the stem looks ok, yet this thing will not stay closed. In all my screwing around could I have damaged the stem and that is what is causing this? I really appreciate any help Ė Iíve had to turn off the hot water to the house until I figure this out. Maybe I just need to get another new stem?
    Steve
    Dose this model have packing for the stem nut? If so, you might need to replace the packing, or tighten it down a bit more. Do you know what your water pressure is?
    Dec 2007
    The packing is too tight so it is turning the stem back.
    You want it to be just tight enough that it doesn't leak.
    Apr 2010
    Virginia
    Thanks to everyone for advice! I loosened the packing and then re-tightened until it was just past finger tight, but the stem still wouldn't stay closed. I went out and got a new stem (the old lady was getting impatient) and that seems to have worked. I'm not sure how I messed up that other stem; maybe I installed it initially with the stem in the off position which I would guess could have slightly deformed the packing as I tightened it. Oh well, problem solved for now...
    thanks again!
    Steve
  1. Price Pfiester bath faucet now turns backward
    By urdrwho in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-16-2010, 03:04 PM
  2. Seized Bathtub Faucet
    By fbskiracer in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2009, 09:03 AM
  3. Bathtub faucet leaks
    By SBeaty in forum Shower & bathtub Forum & Blog
    Last Post: 02-04-2009, 06:39 AM
  4. I need help with a bathtub/shower faucet.
    By Billp142 in forum Shower & bathtub Forum & Blog
    Last Post: 09-22-2008, 07:23 AM
  5. Moen shower faucet turns on when I turn it off
    By Holly in forum Shower & bathtub Forum & Blog
    Last Post: 12-06-2005, 05:25 AM
