Results 1 to 6 of 6
Thread: Stuck set screw in Moen shower faucet
    DIY Junior Member Mikey47's Avatar
    Oct 2010
    Eau Claire, WI
    Question Stuck set screw in Moen shower faucet
    I have a Moen shower faucet (don't know which model) that is a single handle faucet that rotates to turn on and mix the hot/cold water.
    My wife called me at work and told me that the shower wouldn't turn off. When I got home I see that the plastic handle is really loose - it spins from the six o'clock position (off) to the nine o'clock (on full hot).
    No problem I think, it's just the set screw has somehow come loose. However, then I take the cover off the plastic faucet head to get at the set screw and try to turn the set screw -- it turns but it turns the shower on, if I keep turning it gets to the point where the shower is turned off. In fact I can just keep turning the set screw in circles and the shower goes from on to off to on to off, etc.
    So it appears as though the set screw is stuck in the cartridge (since it just keeps turning round and round).
    I have no idea where to go from here...any ideas? If the set screw is indeed stuck (like I think) should the cartridge just continuously turn in circles like I mention?
    Please help as we are not restricted to turn the shower on and off via the set screw with a Phillips screwdriver!!!
    EDIT: So we have Moen faucets in the bathroom too. I just took the plastic handle off of one of those and see how the plastic faucet is molded on the inside to cover the cartridge and hold it in place (or actually turn the cartridge to turn the water on) when turning the set screw. Could this mean that the plastic inside my shower faucet is broken (thus not holding the cartridge in place while turning the set screw)? If so, any alternative than to try breaking the plastic (or cutting it) to get the handle off?
    Last edited by Mikey47; 10-14-2010 at 01:30 PM. Reason: Clarification, added EDIT section on bottom
    Dec 2007
    Call 1-800-BUY-Moen and they will send you the parts you will need....
    Oct 2010
    Eau Claire, WI
    Quote Originally Posted by Redwood View Post
    OK, will do, but how do I get the old plastic faucet off? Hacksaw?
    Dec 2007
    Go here and find your faucet model number. http://www.moen.com/replacement-parts
    Then post it here...
    If you have several others which you have already disassembled and reassembled and what to do is not apparent to you then how would I know what you need to do.
    All I know for sure is that it is a Moen tub/shower valve and it turns...
    That narrows it down some but not enough...
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Sounds like a posi temp valve. The acrilyic handle is broken on the inside so no harm in breaking it off then hold the catridge stem with channel locks and remove the screw. Take the handle with you to a plumbing supplier and match it up and replace it.
    The handle has the stop which limits the degree of rotation, so if it is broken then the stem can rotate, thus, you probably have to cut or break the handle off so you can hold the stem while removing the screw. Then you need a new handle.
  1. Dripping Faucet / Stuck Screw
    By ElCid2000 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2009, 05:43 AM
  2. Sillcock screw is stuck
    By GreenTeam in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2008, 12:14 PM
  3. Stuck set screw on a Peerless One Handle Faucet
    By obrien234 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2007, 05:32 AM
  4. Moen 1225 BODY stuck in bath faucet
    By springishere in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2007, 08:34 PM
  5. removing the screw on a 3 handle shower faucet
    By dacebo in forum Shower & bathtub Forum & Blog
    Last Post: 05-11-2006, 07:28 AM
