Thread: Culligan Gold series softener has constant overflow
    DIY Junior Member kerby's Avatar
    Oct 2010
    Washington
    Default Culligan Gold series softener has constant overflow
    We inherited a 12inch gold series softener and it has worked fine for months but now it is constantly overflowing into the drain. The only thing which stops it is turning on the outside irrigation.
    Can anyone help? Thanks!
    Quote Originally Posted by kerby View Post
    If it runs to the drain, the seals are bad. http://www.culligan.com/en/service-a...olete-manuals/ Try this site and find the manual for your unit. You may need to replace the piston as well as the seals and spacers.
    Dec 2009
    Alaska
    When you say that it is over flowing to the drain, is that the main valve or the brine tank?
    If it is the main valve then either the main piston and seal assembly has a seal out of place , the piston has a grove are the only two real items that will have the unit dumping water to the drain when the unit is in service.
    If it is over flowing the brine tank then there is a plug in the injector assembly area, most likely the injector and screen are pluged.
    Culligan is looking for 150.00 at least for the rebuild kit that has the main piston with seal pack and the brine piston with its cage.
  1. Replacing boiler with a gold series, good deal??
    By Gnfanatic in forum Boiler Forum
    Last Post: 07-22-2010, 03:46 AM
  2. Culligan softener problem
    By TLplumbGuy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-02-2009, 01:45 PM
  3. Kinetico Sulfur Guard vs. Culligan Iron-Cleer/Gold Softner
    By marcopolo in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-21-2009, 01:09 PM
  4. Culligan 812 water softener
    By dougomni in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-11-2007, 07:42 AM
  5. Please help -- culligan water softener problem
    By ADRamsey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-11-2005, 08:26 AM
