Results 1 to 3 of 3
Thread: Dryer Vent pipe leaks water on the floor.
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    Default Dryer Vent pipe leaks water on the floor.
    We purchased a new Electric Dryer and since it was installed the vent pipe leaks a lot of water on the floor. The old dryer didn't do this. I'm a well driller not a dryer expert. Any help would be appreciated.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Could be a blockage in your vent, have it cleaned out and see if it stops.
    What kind of vent pipe is it? If it's the plastic, corregated stuff, throw it away and replace with solid pipe, either aluminum or galvanized. How long is the run and how many elbows? What's likely happening is the air is full of moisture, it is slowing down and lingering in the vent long enough so that some of it is condensing, running down the vent onto the floor. If there are any obstructions (clogged line, too many elbows, rough from the cheap plastic, or lots of lint in the pipe), it slows donw and isn't staying a gas.
  1. Black pipe/dryer vent spacing?
    By mastas in forum Plumbing Forum Discussion & Blog
    Last Post: 11-27-2009, 05:55 AM
  2. Convert dryer vent to range hood vent?
    By petergunn in forum HVAC Heating & Cooling
    Last Post: 11-10-2009, 03:42 AM
  3. Dryer vent pipe does not go all the way to the roof in attic
    By Reniassance man in forum Remodel Forum & Blog
    Last Post: 07-18-2005, 05:55 PM
  4. Can I vent New bathroom vent into dryer vent line?
    By cwolters in forum Shower & bathtub Forum & Blog
    Last Post: 04-25-2005, 04:03 PM
  5. dishwasher air vent leaks water
    By minocqa in forum Plumbing Forum Discussion & Blog
    Last Post: 03-17-2005, 04:30 PM
