Designie
Well, I finally have the entire water system hooked up and running. The system specs are:
1hp, 10 gpm pump at 210', 32 gallon pressure tank, 40/60 pressure switch.
I ran the system with one outdoor spiggot fully open. The tank will supply water starting at 60 psi for about 2 minutes, then the pump kicks on at 37 psi and takes 3 min. 15 sec. to fill the tank back to 60 psi. So about 3:15 on, 2:00 off for the pump. That's with one spiggot full open.
Being as this is my first time working with any of this, how does this sound?
