Results 1 to 6 of 6
Thread: Can you use a 277V switch on a 120V circuit?
    DIY Junior Member philefriendly's Avatar
    Aug 2006
    Seattle, WA
    Question Can you use a 277V switch on a 120V circuit?
    Hi-
    I happen to have an occupancy sensor/dimmer switch that is rated for 277V, and I'd like to use it for a light on a regular 120V circuit. Would this work? I'm skeptical because the switch (Wattstopper WD-180) only says it is rated at 277V, whereas they do have other models that are rated 120V-277V.
    Thanks in advance!
    Probably not since it is electronic. Maybe, you'd have to call them to be sure, or read the installation manual, if available on-line, to find out. Non-electronic stuff like simple switches, wires, connectors, etc. that are rated for (maybe much) higher voltages than planned, are fine to use on a lower voltage. Electronic stuff may or may not work at a lower voltage.
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Since it is rated at 277, it requires that voltage to operate.
    As you have found out, they make a 120/277 rated sensor, and that would work.
    Yes I am A Pirate-Jimmy Buffett
    Plumber jimbo's Avatar
    The WD-170 is the 120 volt model.
    A simple on/off mechanical switch would be rated for its maximum voltage, but one with an electronic function will only work at the specified voltage.
    Most electronic stuff is marked with a voltage range, if it can work with various inputs. When it is listed with one voltage, generally, that's it.
  1. Can 2 lights (same circuit), 2 switched, be converted into one switch?
    By casualfc in forum Electrical Forum discussion & Blog
    Last Post: 10-11-2010, 02:02 PM
  2. Convert 220 circuit to 110 circuit to be run to new subpanel
    By C Willard in forum Electrical Forum discussion & Blog
    Last Post: 10-24-2009, 06:39 PM
  3. circuit selector switch
    By beekerc in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 03:08 PM
  4. Is this switch ok for a 15A circuit?
    By Fistor in forum Electrical Forum discussion & Blog
    Last Post: 06-17-2008, 01:36 PM
  5. 240V electric water heater on 120v circuit
    By miscmail1560 in forum Electrical Forum discussion & Blog
    Last Post: 12-12-2007, 04:52 PM
