Results 1 to 2 of 2
Thread: Winterize Domestic Water
    DIY Junior Member Wide Glide's Avatar
    Oct 2010
    US
    Default Winterize Domestic Water
    Closing my camp and want to pump RV anti freeze into the tankless coil and all the domestic lines in the hot water boiler. The house has a well trol, do I pump down the cold side from the well trol drain. By doing this will this drain the hot side from the well trol drain? Then remove the pressure relief valve and screw on a gate valve and pump anti freeze into the domestic side. Then after pumping a while open all the faucets. Can anybody comment or have recommendations.
    Are you running antifreeze in the boiler circuits? If you do, you lose about 10% of the capacity, since it doesn't transmit heat as effectively.
    I would guess you could just blow the lines out with an air compressor for the domestic water lines. You'd need to put antifreeze into the traps of the drains, but nothing else. If you were lucky, the lines were installed with the intent of draining, and you could just open a valve, but that doesn't happen too often.
  1. Winterize lake water intake to cottage
    By lhartl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-02-2009, 05:54 PM
  2. Copper in Domestic Water
    By Neil ACCI in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2008, 08:22 PM
  3. domestic hot water
    By Michaelt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2007, 10:41 AM
  4. amount of domestic hot water is reduced
    By bgoldie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2006, 06:58 PM
  5. Very low domestic water volume & pressure ?
    By kipph in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2005, 06:00 PM
