Results 1 to 5 of 5
Thread: Remove a brick? Or drill holes through the brick?
    DIY Member bassadict69's Avatar
    Oct 2010
    Benton, La
    Default Remove a brick? Or drill holes through the brick?
    I am needing to run 2 water lines through my brick wall...should I drill through the brick? Or simply remove a brick and then seal it back up with foam or some other sealant?
    Whichever I should do, what is the best way to do it?
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    I'd drill with a hammer drill and just make the hole as close to the OD pipe you are drilling.
    Seal up the remainder with a good sealant like Sikkens or Sonnerborn sealant.
    Get a hollow core drill bit and you will not "demolish" the other side of the brick when the drill goes through the brick.
    George the Plumber Gsalet's Avatar
    Sep 2010
    San Francisco
    Remember you want to allow space around the pipe so that the pipe does not wear out prematurely from the vibrations caused by the water flowing through the it. Code say 2 pipe sizes larger, I would suggest at least a 1/4 inch around the pipe. I would also suggest some sort of sleeve even if it is only a couple wraps of 10 mill tape, then caulk it up with some hi quality silicone.
    Oct 2010
    Benton, La
    Thanks guys...
  1. Brick pulling away from structure?
    By dabensys in forum Remodel Forum & Blog
    Last Post: 08-11-2009, 05:22 AM
  2. Salvaging Brick
    By shimp in forum Remodel Forum & Blog
    Last Post: 04-07-2008, 04:49 AM
  3. Lighting The Brick Freestanding Fireplace
    By smhowell in forum Remodel Forum & Blog
    Last Post: 12-26-2007, 08:07 PM
  4. Cutting large hole through brick
    By jwray in forum Remodel Forum & Blog
    Last Post: 06-23-2007, 07:50 PM
  5. What Material for Sleeve Through Brick?
    By homewrecker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2007, 07:18 PM
