Results 1 to 2 of 2
Thread: I get a continuous flow of water from the backwash drain pipe (Culligan Medallist)
    DIY Junior Member toddomel's Avatar
    Oct 2010
    Murrieta CA
    Default I get a continuous flow of water from the backwash drain pipe (Culligan Medallist)
    My Culligan water softener all of a sudden has continuous flow of water going through the drain pipe. Not sure what is causing this problem. I noticed this once my water bill doubled from the month previous...any ideas?
    You may get more 'hits' if you post in the softener section. It sounds like the control valve is stuck. Could be the motor has died, a gear broke, or something similar. Now, why that happened may be because the valve is stuck, which jammed things up. Have you tried to force a regen and watched to see if things work?
    You probably want to put this in bypass until you resolve it, or your water bill might be even more nasty next time.
  1. Just moved and reinstalled Culligan Mark 100 and Have Some Resin in Backwash
    By jkmason in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-01-2010, 10:32 AM
  2. culligan Medallist will not regenerate
    By phal in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-18-2010, 05:06 PM
  3. Outside Backwash Drain
    By zientm in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-16-2010, 06:19 PM
  4. Culligan Medallist Water Softener
    By scooter.44@comcast.net in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-12-2008, 10:26 AM
  5. Continuous Water in Basement
    By Koorime in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-14-2005, 02:24 AM
