I love the instant hot water dispensers.
Moen sent me a multi-head shower set up; should get me in and out quicker.
It even has a remote to control it with.
Doing a complete high-end remodel of a home incl all new plumbing. We've got all the basics covered but what are some ideas for "cool stuff" we could add while we're at it? One easy example is a pot-filler (which we will do). What other ideas do you have or recommend? (We're thinking about a bar sink and/or an instant hot water faucet.)
What say you?
A bidet is nice. A second dishwasher. Use one for dish storage, and as they get used, populate the second and alternate dirty/clean as one gets filled. Less cabinet space is needed for the dishes and glasses, and if you have a party, you can wash it all at one time in both. Use one of the hot/cold mixing outside hose bibs: Moen and others make them. Makes it nice washing the dog or car, or hook up to a showerhead for when the kids are really grody before you let them in the house.
How about a hot water recirculation system. That gives you virtually instant hot water at every fixture and it save water especially on the longer runs from the water heater.
Of course the bidet seat. Best feature in the bathroom.
If space allows what I would like would be a hot tub off the bedroom, or a shower with 2 shower heads for 2 people to share; or an indoor wave swimming pool. I would also, like a water fountain outside which would replenish a bird bath. I would also like a pond with a water fountain.
Radient heated floors in bathrooms.
If you go with two dishwashers, all you need are a pair of stacked "dishwasher in a drawer" models, since neither will need a lot of capacity. If you go with multiple shower heads, do it before the "one 2.5 gpf head per shower stall" rule goes into effect.
Bollards to protect outdoor plumbing from lawnmowers. Remember that one anyone?
Actually, it has already been "put in effect", pending approval of the document. The requirement was "buried" deep inside it, and almost passed without discussion. The manufacturers are trying to get it modified, at least to allow multiple devices for handicapped installations. There will be a hearing on it soon, possibly next month. After that it depends on when the effective date is established.
In addition to the pot filler....
1. Pasta sink next to range/cooktop. Very cool, saves you (or the missus) from carrying a heavy pot to the sink. If no room, you can gt a specialty pasta pot but it doesn't have as much wow factor.
2. Water softener (ion exchange, using NaCl or KCl, not the scam ones) to keep everything cleaner, except use hard water for irrigation and hose bibs that service the garden. I also like hard water to the icemaker/cold water dispenser because I prefer the taste of water with the minerals in it.
3. Put one soft water hose bib in the driveway for car washing - no water spots.
4. Instant hot water.... I prefer an mini tank under the sink (I use a Bosch/Ariston - works great - just change the anode every year) over a recirculating system. If you go with recirc, though, think about the setup that doesn't mix hot and cold water (i.e., has a separate return line). Hot water tanks have higher bacteria content - do you want that in your cold (drinking) water?
5. Wall mounted lav faucets. Much easier to keep clean.
6. Even if you decide against the bidet seat for now... put it the electrical outlet "just in case".
7. Humidity-sensing bathroom vent fan - with low "sone" rating. I wired the nightlight option in mine to a photocell instead of a switch so that the night light comes on automatically. Also, for $5 you can use an LED bulb in place of the four watt nightlight bulbs that always burn out.
8. Not plumbing, but put electrical outlets in the medicine cabinet for your electric toothbrush charger, etc. That way you don't see the cord clutter on the vanity counter.
9. Stainless restaurant kitchen type prep sink in the garage, if you work in there. Use a foot or knee operated faucet. Also useful in the laundry room or mud room.
10. If your kitchen design is one of those styles that looks like a commercial restaurant kitchen, consider a foot faucet in there, too.
11. I like a counter-mounted air switch for the disposal instead of the typical wall mounted light switch.
12. If you have a pool or spa, an outside shower with a some sort of instant hot water service.
13. An outdoor sink as part of the grill/outdoor kitchen installation.
14. Run the grill off of natural gas... no refilling the propane tank.
15. Drip irrigation on its own timer zone - or more than one if your garden requires it - in addition to the lawn sprinklers.
16. Plumb the rain gutter downspouts to run underground out to the street... away from the foundation.
IHW. 1/2 gal. or 5/8 gal.
small sink near potfiller + big single sink for cleanup + prep sink +
Filtered water.
Chiller, not in fridge.
Floor drains.
Chest freezer, that requires defrosting (therefore is passive cooling, no freezer burn).
2 small DW.
Put a 20 gal tank near the kitchen, and a 40 gal near the bathroom.
