Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Pipes bang hard when cold water on full blast
    DIY Junior Member Carri's Avatar
    Oct 2010
    USA
    Default Pipes bang hard when cold water on full blast
    This did not happen prior to our bathroom remodel. Only after our bathroom was redone did the pipes start banging when the cold was on full blast, but this only happened at the kitchen sink. The banging did not happen when you turned the water off. It was when the cold water at the kitchen sink was on full blast that it happened. The remodeled bathroom is on the second floor, not above the kitchen, and if you turned the cold on full blast at the kitchen sink, the pipes in the kitchen started banging really badly.
    So we got in touch with the contractor who redid the bathroom, and his plumber did not know why the banging was happening. He tried to remove air from the pipes but that did not solve the problem. Next he installed a vertical piece of pipe in the upstairs bathroom under the sink (picture one attached) but this also did not solve the problem. Now tonight he installed a different type of vertical piece of pipe in the kitchen under the sink (picture two) and this seems to have stopped the horrendous banging.
    It seems that these vertical pipe pieces (on the cold lines only) are a patch to the problem, which was not a problem before the bathroom remodel. Our plumber seems to want to blame our new Jado valve, saying that it causes too much pressure in the lines. We want to know why this banging happened in the first place (only the cold full blast in the kitchen) and whether these vertical pipe pieces make any sense. We do not want to have to drain the lines periodically so this alleged patch job continues to work.
    PSI is 65. Thoughts please? Thanks in advance.
    Picture One
    Picture Two
    Jun 2009
    Canada
    The first chunk of copper is useless, the second is a proper water hammer arrestor.
    What happens if you regulate the pressure down to 50psi instead of 65?
    Oct 2010
    USA
    Not sure how to change the PSI to 50 but if you turn on the outside garden hose and cold at the kitchen sink, the kitchen pipe banging seemed to stop. The thing is though that PSI 65 did not bang any pipes prior to the bathroom remodel.
    Dec 2007
    There is either debris in the pipes or a loose washer on a valve somewhere...
    Oct 2010
    USA
    Thank you for the replies. Four more questions please...
    Do you think it is possible to fix the pipe banging without the use of these vertical pipe pieces?
    If the upstairs vertical pipe piece is useless (picture one in first post) should it be removed?
    If these vertical pipe pieces stay in place, will we need to drain the lines periodically to prevent the banging from coming back?
    Could the pipe banging have been prevented in the first place?
    A hammer arrester is an engineered device with a sealed air chamber (a piston or bladder - yours has a piston separating the air and water). It works until it fails, and that should take many, many years. The first one is an old school air chamber...open to the water, and very quickly all that air will disolve into the water stream as it passes, and be useless. Shutting and draining the lines usually won't restore the air (think finger over the top of a straw). SO, shortly, it will be come useless. It could stay, but it isn't doing anything.
    Water hammer is caused by moving water stopping rapidly, causing the pipe to continue to move via inertia until it hits something, like a hammer, and you hear the noise. A constant vibration is usually caused by either some debris bouncing in the pipe against something that is then restricting the flow, and the pipe then vibrates. As noted, if there is a valve with a loose washer, that washer can vibrate as water passes, changing the water flow, similar to some debris. You may have to remove the aereators from the faucets, maybe the cartridges, and the toilet fill valve then turn the water on to see if you can dislodge any debris.
    Make sure all shutoffs are fully opened, and if not 1/4-turn ball valves, you might want to consider changing them to that type (1/4-turn valves don't have traditional washers and have less restriction).
    Dec 2007
    Quote Originally Posted by Carri View Post
    yes, it doesn't matter, no because it hasn't solved the problem, probably not
    The real problem that what you describe is NOT conventional water hammer which occurs ONLY when a faucet or valve is closed suddenly. It does not happen while water is flowing, so we cannot tell what the cause was, or why the arrestor "cured" it.
    DIY Junior Member VernK's Avatar
    Oct 2010
    Kelowna, BC
    The arrestor, in this case, added a "spring" to the system and maybe luck just had it that it was just the right rate to damp the vibration
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    If the arrestor works under all conditions can we say logically say that there are pressure waves in the system?
    Regarding "full blast", turbulence must increase with fluid velocity, right?
    Was the banging once per second, 5x per second. . .?
    Are the pipes clamped at the recommended intervals?
    George the Plumber Gsalet's Avatar
    Sep 2010
    San Francisco
    Don't forget about pressure balance shower valves with check stops, If debris gets in the stops it will cause the pipes to bang when anything is turned on randomly.
    Aug 2008
    MD
    So if the problem were debris the noise would have stopped anyway if the plumber just waited.
    Debris is the least likely source of the noise and would have been evacuated as soon as the water was turned on and the faucets used, anyway.
    Dec 2007
    Quote Originally Posted by Thatguy View Post
    Well it would stop if the debris/loose washer was flushed out or, removed...
    Right now the arrestor is dampening the pulsations that are still there or, the debris moved to where it is not a problem at the moment.
    Aug 2008
    MD
    I guess the next logical step is to buy a pressure gauge for a few bucks and see what it says.
    Also try turning off the water using a washing machine, which valves work very fast, and see if that brings back the banging.
    Try as many different ways as you can to bring back the problem so as to provide troubleshooting clues.
    Or hope that the problem never returns. Hoping is free, even in this economy.
  1. Pipes bang with water filter turned on (not run-of-the-mill)
    By callmebill in forum Plumbing Forum Discussion & Blog
    Last Post: 05-10-2012, 11:20 PM
  2. Replace copper pipes or line them here in hard water-plagued san diego county?
    By ilabadie in forum Plumbing Forum Discussion & Blog
    Last Post: 05-08-2010, 07:45 AM
  3. Takagi TK2 running at full blast constantly
    By tomallinder in forum Plumbing Forum Discussion & Blog
    Last Post: 08-06-2008, 12:22 PM
  4. Takagi TK2 running at full blast constantly
    By tomallinder in forum Tankless Water Heater Forum
    Last Post: 08-03-2008, 07:28 AM
  5. Pipes bang when turning water on
    By richardoc33 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-14-2007, 04:47 AM
