Results 1 to 3 of 3
Thread: pressure balancing loop for 4 sprays
    DIY Junior Member docpop's Avatar
    Oct 2010
    pittsburgh
    Default pressure balancing loop for 4 sprays
    i am installing 4 22-nozzle kohler body sprays (all controlled off of one volume control). i have searched for how to plumb for 4 sprays. i have found diagrams for 2 and 3, but not 4. the manufacturer siad that i did not need to run 2 separate loops and have 2 separate volume controls for 4 sprays, but i cant seem to find how to plumb it. my thinking was to have an "H" formation with the 3/4" pipe t-ing to 2 other t-s and place each spray and the ends of the "H". not really a loop, but water pressure should still be held constant throughout. any ideas or suggestions?
    That is the way I would do it. I have NEVER installed a "pressure balancing loop", since all they are is a way to waste time and money.
    George the Plumber Gsalet's Avatar
    Sep 2010
    San Francisco
    I suggest using the loop this way each head will evenly spray, Other ways may work and may not depending on volume and pressure. Check out this pdf from grohe page number 9
    http://www.schematixdesign.com/pdf/Grohe_Binder_Pages.pdf
  1. Pressure balancing loop for Moen vertical spa
    By twilight in forum Shower & bathtub Forum & Blog
    Last Post: 07-29-2010, 01:54 PM
  2. Pressure Balancing Loop
    By M3 in forum Shower & bathtub Forum & Blog
    Last Post: 02-04-2010, 05:22 AM
  3. Pressure loop for body sprays.
    By Erico in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2010, 07:33 AM
  4. Body Sprays - Does this "loop" work??!!
    By dixiedoodle in forum Shower & bathtub Forum & Blog
    Last Post: 03-05-2007, 12:12 PM
  5. how do you make a pressure balancing loop?
    By gib7464 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-26-2006, 05:04 PM
