Results 1 to 5 of 5
Thread: New fill valve leaks
    DIY Junior Member dehulton's Avatar
    Oct 2010
    Virginia
    Default New fill valve leaks
    I just replaced a leaking fill valve with a new K830-15 mini pilot fill valve. The new fill valve has a slow leak that eventually reaches the top of the pipe and flows into the bowl. Any suggestions on what might be wrong? Thanks!
    You may have some crud caught underneath the seal. Not familiar with that specific style, but you might remove the seal, clean things up, then momentarily open the supply line to flush it out (use something to keep it from spraying all over), then reassembly. When you disturb pipe, you often dislodge crud in the lines.
    Also, you might want to check your water pressure. If it is excessive (over 80psi), you should install a PRV and expansion tank. If you have one, it may have failed.
    Dec 2007
    Tear it out and replace it with a Fluidmaster 400A
    The K830-15 is junk no matter what name or number they attach to it!
    Oct 2010
    Virginia
    Thanks for the advice, I will give it a try
    Oct 2010
    Virginia
    Thanks for the advice. I suspected that was the case.
  1. Water use - hissing G-Max Korky 528 fill valve - Quiet Fill
    By urdrwho in forum Toilet Forum discussions
    Last Post: 09-23-2012, 04:15 PM
  2. Toilet Valve Running with not Fill Valve Leaks?
    By tombstone in forum Toilet Forum discussions
    Last Post: 09-14-2009, 11:25 AM
  3. leaky fill valve AND shutoff valve
    By moray in forum Toilet Forum discussions
    Last Post: 03-22-2009, 11:12 AM
  4. Toto Fill Valve Problem Continues G-Max valve with adjusting screw
    By levitonski in forum Toilet Forum discussions
    Last Post: 12-02-2008, 12:40 PM
  5. Best fill valve...
    By sparkg in forum Toilet Forum discussions
    Last Post: 10-09-2006, 01:18 PM
