Results 1 to 2 of 2
Thread: Replaced compression valve stems - hard to turn
    Default Replaced compression valve stems - hard to turn
    I just replaced both shower faucet compression valves and valve seats. When I installed them I greased them with plumbers grease, but after a day or so they are hard to turn again. What did I do wrong?
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Default faucet
    Do those stems have a packing gland that you may have over tightened ?
    Or do those stems use o-rings for a stem seal ?
    If so , did the stems come with the o-rings on ?
    What do you mean when you say compression valves ?
