Results 1 to 6 of 6
Thread: Reconnecting radiator with black pipe connections
    DIY Junior Member johna's Avatar
    Oct 2010
    Toronto ON
    Default Reconnecting radiator with black pipe connections
    Hello,
    I've just finished tiling my kitchen. There are two previously capped off black iron pipes coming up through the tile. My plan was to reconnect the radiator (which had been removed by the previous owner). I'm not sure how to handle this problem, though: the tile has raised the floor about 3/4", so the one pipe is now too short for the cast-iron radiator. The other is, for some reason a few inches shorter and barely protrudes from the tile (I cut the tile around it out a little more to allow for some kind of union. What can I use to make up the 3/4" on the one side? For the shorter side, I bought a union with a tapered-seat joint and a variety of lengths to make up the distance, but again, matching the height exactly seems almost impossible. Should I be using PEX instead? Or brass reducing bush to copper to elbow to RH/LH nipple to radiator? Should I avoid these dissimilar metals to avoid a galvanic reaction?
    Kind of a convoluted situation; appreciate any advice. Thanks,
    John
    In the Trades Wally Hays's Avatar
    Nov 2009
    You could try cutting down the legs on the radiator. Have you tried prying the pipes up a bit. They may have slipped down during renovation
    Perception is 3/4 of reality
    Aug 2009
    South*East
    You can use a extension coupling. They may be hard to find.
    http://www.homefixitparts.com/showpa...cat=Extensions
    John
    Oct 2010
    Toronto ON
    Thank you for the suggestions. I'll see if I can source an extension coupling. Lots of custom work in an old house like this...
    Oct 2010
    Toronto ON
    OK, googled "extension coupling," which brought me to "street coupling," which brought me to a few other forums where there were unhappy people with the same problem. Street coupling would work for the short side, anyway.
    http://www.bicwarehouse.com/red-bras...filiate&aff=cj
    Will I have "galvanic reaction" problems if I put a piece of brass in between the black steel pipe? (I've heard using galvanized is a no-no.) Closed system, so oxygen gets used up and corrosion stops, right?
    Normally, you will connect the radiator to the pipes with a "union valve" on the feed side and a "union return elbow" on the other end, thus you do NOT need any other unions.
  1. UK Radiator Valve and US Copper Pipe
    By AlexandriaRemodeler in forum HVAC Heating & Cooling
    Last Post: 02-25-2009, 05:23 PM
  2. Help reconnecting a 4-way switch
    By karensw in forum Electrical Forum discussion & Blog
    Last Post: 08-12-2008, 02:03 PM
  3. Steel to Clay Pipe connections....
    By sowatson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2008, 07:34 PM
  4. Brass Pipe Thread Connections...
    By OldPete in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-19-2006, 05:32 PM
  5. type M copper pipe connections
    By Al Dente in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2005, 11:35 PM
