If you stated the problem correctly, and we have to assume you did, then no you cannot do that. The flushing water from the toilet would create a venturi effect and pull the trap seal from the tub's "P" trap.
I have a toilet that has its own vent that comes off about 8" below the top of the toilet drain. it comes out with a 3" diameter and then reduces to 2" as it goes up the wall. can I tye the tub drain in down stream and use the toilet vent to vent the tub.would that beallowed?
thanks for any feed back.
