Results 1 to 5 of 5
Thread: Is it a bad idea to drain softener into the ground?
Hybrid View
    DIY Junior Member Mastiff's Avatar
    Sep 2010
    Tucson AZ
    Default Is it a bad idea to drain softener into the ground?
    I'm installing a softener and the install point is outside far away from any convenient drain. The Kinetico guy was going to go up onto the roof and drain into a vent. We live in the desert here and I was really wondering if it would be okay to drain onto the ground. Maybe dig a big hole and fill it with gravel or something like that. We live on an acre of gravel and cactus outside the city limits. Opinions?
    Dec 2009
    northfork, california
    I doubt that the desert would suffer much from some more salts added to its others.
    If you are on a well, which is unlikely, you might not wish to do so.
    The city eventually dumps your residue on the earth anyway.
    Sep 2010
    Tucson AZ
    Well, I decided to try it. I dug a big hole and filled it with rocks. We'll see how it goes.
    In the Trades Wally Hays's Avatar
    Nov 2009
    Try not to dump it anywhere near your wifes flower bed
    Perception is 3/4 of reality
    I hope it is a BIG hole, because the backwash phase discharges a lot of water.
  1. Draining a water softener into a septic system...bad idea?
    By Mikebarone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2013, 06:20 PM
  2. Removing tub drain from septic system, good idea or bad idea?
    By Briandl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-12-2010, 06:19 PM
  3. Leaking drain under slab - crazy idea that I would like to run past everyone
    By gmorstadt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2009, 04:19 PM
  4. Will this idea work for double vanity drain?
    By cable_w in forum Shower & bathtub Forum & Blog
    Last Post: 08-13-2008, 12:36 PM
  5. Wife wants a Water Softener. Bad idea?
    By LawyerRon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2007, 07:17 AM
