Results 1 to 3 of 3
Thread: Problem with reverse osmosis filter
    DIY Junior Member Stonkey's Avatar
    Oct 2010
    NY, USA
    Default Problem with reverse osmosis filter
    My reverse osmosis filter is having some trouble. I am not getting any water flow from it whatsoever.
    I changed the small flavor filter, air tank, flow regulator on the waste line, all three initial stage filters, and the reverse osmosis element. Basically the only thing that I did not replace was a short, silver cylinder that has 4 tubes on it. I don't know what that is. I know that the water line to the filter is good, and I can even hear a trickle from the waste line, but I get no water to the taps.
    Anyone have any ideas what might be the problem? What other information do you need? And what pressure should I keep the tank at? I've been playing around with various pressures, but nothing seems to work.
    The "thing" with 4 tubes on it may be the pressure regulator, which determines whether the unit has to produce water or not. It could be defective, or you could have too much air in the tank so the regulator thinks it is full already. If you get a trickle down the drain, it should be making water.
    Oct 2010
    NY, USA
    While I look into getting a new regulator, can you tell me what is a good pressure to keep the tank at?
  1. Reverse Osmosis Filter Stops Making Water
    By Shinshi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2010, 07:20 AM
  2. RO filter ( reverse osmosis ) ?
    By tommy vercetti in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-15-2009, 06:21 PM
  3. Reverse osmosis Water Filter
    By Terry in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-22-2009, 05:55 PM
  4. Reverse osmosis Water Filter
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2009, 11:13 AM
  5. Reverse Osmosis filter and water pressure
    By Kai in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-25-2005, 04:45 PM
