Results 1 to 7 of 7
Thread: General Questions about 2 Tank Heater System
    DIY Junior Member Jimmy314's Avatar
    Oct 2010
    Oregon
    Default General Questions about 2 Tank Heater System
    Hello,
    We have a home with two 50 gallon electric water heaters. They are both working but very old (27 years). The house is 3 bedroom 2.5 bath 2000 sq ft. One heater is in the laundry room and the other in a closet by the bedrooms.
    Im sure I could crawl under the house to check, but I was wondering if they would typically be plumbed together or are the hot water systems separate? If they are separate, it seems that the one in the laundry room is too big as it would only feed the dishwasher/kitchen sink and the laundry machine. Maybe a small tankless electric heater would be better here?
    The second water heater feeds two bathrooms and is working okay but the temp is not consistent. I changed the thermostat a few years ago, but the problem has returned. AT 27 years old we are fine with replacing this unit. We figured we would look for the most efficient regular replacement. There is no room for hybrid and Im not sure if we want a tankless unit for bathroom/showers after reading the consumer reports.
    We do have natural gas at the house, but we do not want to convert due to high installation cost.
    Any advice on what would be an efficient upgrade to our system would be appreciated.
    Jim
    A tankless for electric would require work at the main panel and new wires run to the heater. They use a lot more power then the storage type tanks, which heat slowly with little power needs, and then store it.
    If you are going to "fry" your water, you need an electrician first.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Try closing the valve to one of the tanks and check the fixtures for hot water, this will tell you if they are plumbed seperatly.
    For hardware longevity, the electric WH often last longer than a gas one. Whether it would end up less expensive to operate it depends entirely on your local electrical rates verses gas. In most places, a gas WH is a lot less expensvie and has a faster recovery rate than electric. Since it is very unusual for either an electric and much less a gas unit from lasting that long, you would likely end up replacing the gas more often, which would eat into the energy use cost differences. to maximize the longevity, replace the anode rods periodically and flush the crud buildup that settles on the bottom.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Jimmy314 View Post
    My gas water heater used 31 therms of energy in one month and cost the two of us $60.
    If it were electric at $0.15 per kwh it would cost me $136/month for this same 31 therms.
    Let's say I had an elec. heater and routing the gas pipes costs $2K.
    $2000/($136-$60) = 26 months for the conversion to pay for itself.
    Try your own numbers.
    People move to a new house in 7 years on average, and this is less than the service lifetime of either type of heater.
    Oct 2010
    Oregon
    Thanks for the replies. Good idea of closing off one of the tanks to see if they are plumbed together, much easier than crawling under the house. Our electric bill is rarely over $90 and based on the costs it appears that the electric tanks are still the best choice. The break even for switching to natural gas would be many years.
    Without testing the system there is no way for us to tell you which way it is piped, since there is no "standard" way. It depends on how the plumber was feeling that day.
  1. Re-locating an Aerobic Septic Tank System or use system as-is?
    By pearlbluevtx in forum Plumbing Forum Discussion & Blog
    Last Post: 02-08-2010, 09:50 AM
  2. General Resin questions
    By Towman in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-26-2009, 03:48 PM
  3. General questions on replacing water service DIY-style
    By dgeist in forum Plumbing Forum Discussion & Blog
    Last Post: 04-14-2009, 05:22 PM
  4. Mo-DAD (modad) septic system - general & specific questions
    By bgpenhollo in forum Plumbing Forum Discussion & Blog
    Last Post: 12-28-2007, 06:08 AM
  5. Well System Questions
    By dyoungers in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-14-2006, 08:48 AM
