Results 1 to 7 of 7
Thread: Tub Spout Height
    DIY Junior Member bet3zzz's Avatar
    Jul 2010
    Default Tub Spout Height
    I am installing a Sterling/Kohler tub with integral tub surround similar to this one:
    you may want to link to the Sterling web site.
    For some reason, the instructions call for the tub spout elbow to be 25" off the floor minimum. Since the tub is 15" high, this puts the spout at 10" over the tub, which seems way too high. It has to be a bit higher than with the old tub because of the way the tub and walls fit together, but I see no reason why it has to be that high. Heck, if I put in in at that height, the valve will be too high to get at from behind via the access panel.
    Does anyone know why this height would be specified? Maybe because of the way the walls assemble or something? Is there a standard height for the spout? How about for the valve?
    Plumbing code requires that the low part of the spout be 1" higher then the flood level to prevent siphoning.
    If I know there will be 4-1/4" tile, I put the spout at 4-1/4" from the top of the tub.
    If the tile is 6", then I put it 6" above.
    There isn't a real hard and fast rule to this.
    Except for the 1" air gap.
    There's the code issue about the floood rim, and then there's the valve's minimum requirements about the separation of the valve from the tub spout. Unless you have some strange addendum to the plumbing code where you live, all you have to comply with is the flood rim one. Not abiding by the valve's minimums just might mean it doesn't work well, though, so you want to address that as well.
    The "minimum" is an engineer's concept and has nothing to do with reality or the functioning of the valve. I put the spout about 6" above the rim and the valve itself wherever it is best for the user to access it, whether that is 6" above the spout or 42" above the floor.
    Jul 2010
    Thanks everyone. I think they may have specified that height because of the wall surround assembly process (i.e., the way you pivot the walls into place). I've got a door frame in the way, so I can't assemble it the way they the instructions say anyhow, so I went with 6" above the tub rim, and put the valve as high as I could go and still get at it from the access panel.
    If you installed it correctly, you should NEVER need the access panel. I haven't installed a tub/shower valve with an access panel in over 40 years. ANd before that the only access panels were for the tub's drain, NEVER the valve.
    Pretty much all tub/shower valves can be repaired from the front. Generally, it is just a cartridge replacement, and on most, you don't even need to remove the trim, only the handle. So, access from behind is only required when replacing the whole thing, and then if it is part of a remodel, you may be replacing the tile or enclosure too, so access from behind isn't a big deal.
  1. Height of tub spout and valve
    By miamicanes in forum Shower & bathtub Forum & Blog
    Last Post: 11-10-2009, 10:34 AM
  2. Highest height on comfort height toilet
    By BOB J in forum Toilet Forum discussions
    Last Post: 03-05-2009, 12:43 PM
  3. p trap height
    By theslosk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-15-2008, 07:43 PM
  4. getting ADA height with non-ADA height units
    By avocats in forum Toilet Forum discussions
    Last Post: 09-04-2007, 05:26 AM
  5. Standard height vs. comfort height
    By Cygarbuff in forum Toilet Forum discussions
    Last Post: 11-12-2004, 08:35 AM
