Results 1 to 8 of 8
Thread: "Wet" changing electric water heater elements.
    Dec 2009
    northfork, california
    Default "Wet" changing electric water heater elements.
    Does anyone else save a ton of time by not draining the electric water heater to change an element?
    Release pressure, then close all valves above.
    Pull the element, the loss of water is minimal without a vent.
    Can usually be done and lose less than a gallon. Of course you need to be on a drain pan or in the basement.
    Probably not a good idea on a T&M job however.
    Dec 2007
    I have...
    I would not advise a DIYer to do so...
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    What's the downside, if any, to doing this?
    Dec 2007
    Water spilling...
    Always, and I place a towel on the floor to catch the water.
    DIY Junior Member frankflynn's Avatar
    Oct 2010
    Palo Alto, CA.
    Water spilling...
    A lot of water spilling. I've done it, it does work just don't do both the top and bottom elements at the same time
    Dec 2007
    I seldom do it.
    With the bottom element removed I use it as an opportunity to break up the minerals accumulated in the bottom of the water heater and remove them.
    Dec 2009
    I use a shop vac with a garden hose to smash and suck the bottom when needed. If they gave us a nice 1" port at the bottom, all would be easy.
    "they" dont want it easy on us.
  1. Price "guess" Tankless Water Heater/10 Gallon storage and existing recirc pump
    By anitarenner in forum Tankless Water Heater Forum
    Last Post: 10-28-2010, 02:34 PM
  2. Water heater and "closed" systems
    By djcd34 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-15-2009, 05:06 PM
  3. water heater "heat loops"
    By edwardh4 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-18-2008, 04:08 AM
  4. Electric "table top" water heater.
    By Robert Ragaini in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2006, 09:01 PM
  5. Pressure Balance for "on demand" water heater
    By hopkinsck in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2005, 07:41 PM
