Originally Posted by
WE would have to see the diverter stem to see why it is happening. The problem is usually with the back seat, NOT the one in the faucet. With a double seated stem, BOTH seals have to occur at the same time when it is installed. Having too thick a "seal ring" where the stem contacts the valve body, can prevent the inside seal from occurring. Try removing that ring and using Teflon tape instead. This may solve your problem, but if it does, also check to be sure the stem is not leaking where it screws into the valve body.
