Where are you noticing this? In the shower? Using hot water? There could be hard water intrusion from a water heater not yet fully softened. It may take a few days before it is fully flushed out and replaced with nice, clean softened water.
Having had soft water at a relatives house, the water was quite slick.....like not being able to get all of the soap off in the shower.
Have installed my Aquapure with Clack ws-1 cs valve (amazingly no plumbing leaks) and the water is softer but not as slick as I expected.
Could slightly overshooting the numbers in setting the clack cause this? I have 6-7gpg and the softener is set at 11k grains and 3lbs salt. I did not change the p setting since the aquapure manual did not indicate this.
Could be the problem. I have a recirculation pump that pull hot water down to the kitchen faucet intermittently so that it does not take as long for hot water to get there. Maybe there is significant residual unsoftened water in the tank?
I guess I will give it a few days.
The water should be super slick right?
When I initially filled the tank I think I opened the valve a little too quickly. There werent any resin beads in faucets....I dont suppose they could get into the valve and bugger it up somehow?
How long has the system been in and runnning?
1.5 days (in service Sunday morning)
It is most likely going to take about another day or two for the pipes to fully clean up and the water heater to change over to the treated water.
The longer the house has been on untreated the longer it takes to clean up.
I have had customers take 1-2 days and some take up to a week to fulling clean up the pipes ..
When you say clean up the pipe do you mean finally washing out all unsoftened water?
Yes, the untreated or hard water that is in the water heater, and the scale that is inside the pipes and working out.
The pipes might have scale and the water does not, thus first thing after a night of no water running the scale goes back into the water as the water if free of it.. and depending on the build up or how hard that build up is tells the time that it will take to work out of the plumbing of the house.
You could just flush the water heater, too, but as mentioned, it will take a day or so. Let us know. If it continues on again, off again periodically, then your softener is letting hard through and should be reset. With just 6-7 grains of water, I can't imagine that a small bit of scale build up would make thje soap not lather. yes, there may be a little build up and it may wear away in time with the softened water, but the main cuplrits are hot water tanks and hard water intrusion, such as a leaking by-pass.
To determine the difference, wash hands in only cold and only hot to see if there is a difference.
Now what is really important is that the softener is set up correctly. IOW, if the softener runs out of capacity before it regenerates and you continuously refill the water heater with less than 100% softened water, then this problem becomes chronic. When I see iron stains in washers and showers, for example, but not toilets, it often says that the softener is occassionally letting the heater fill up with hard water. That's why someone should always check both for hardness.
I had a customer that felt the slick feeling, but when I moved her softener to another home in the same city (different water source) it went away. The water stayed soft, but the slickness went away. I always felt it was water chemistry.
Used sharkbite valves to set up the bypass. Dont think there is any significant leak (couldnt hear anything when I close the valve and there was no flow whatsover)
The water is definitely more slick than baseline water. I will give it some time and if there is any doubt, will test the water.
I should consider myself fortunate that with the long run I had to make with several turns that there were no leaks. There is also no discernable pressure drop, but I did use 1" pipe to make the bypass loop.
I think the softener is set up right (or slightly overestimated capacity).
Softened water dissolves hard water scale build up in the plumbing and water heater, adding hardness back into the softened water until all the scale is removed. That causes hard water although the water coming out of the softener is 0 gpg soft. Dissolving the scale can take a few days to weeks because it depends on how much scale there is in the system and how much water is used.
Going by the feel of the water is not a good test, test for total hardness right after the softener, that's the only way to tell if the softener is working properly.
There is not a single shred of evidence that soft water will dissplve hard water deposits. All the available information on the subject deals primarily with quack science water treatment such as easy water, Zeta rod and all the other carnival tent products that claim to remove existing scale but do not. In order to remove existing scale from piping and appliances either a acidic solution must be introduced or the water must be heated to the boiling point and somehow Co2 has to be added to the mix.
Perception is 3/4 of reality
So you too have not seen softened water dissolve hardness scale. I can't tell you how many domestic coil water heaters I've opened up by installing a softener, but that wouldn't do any good anyway.
I'd be happy to not have slick water, I find it annoying not being able to get all the soap off in the shower.
