Thread: oil furnace problems
    DIY Junior Member jaycafe's Avatar
    Oct 2010
    Ontario
    Default oil furnace problems
    I have an issue with my furnace not turning off. It will start fine, at the desired temp, but the blower won't stop (only sometimes it stops). I usually have to go downstairs and turn off the power to the furnace for 10 minutes, then the blower seams to reset itself. I do have an electronic thermostat thats only 2 years old and has fresh batteries.
    Is there a relay or somthing, that is screwing things up?
    Any help would be great!
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by jaycafe View Post
    Please post a schematic.
    For intermittent problems I'd check for loose connections.
    You can also check for Technical Service Bulletins that the manufacturer may have issued regarding this problem.
    Do you have a multimeter?
    Jan 2009
    Many hot air furnaces control the air-handler with a snap-disc type thermostat on/near the heat exchanger, which should be turning off the contactor/relay for the blower motor once it has cooled. They sometimes get sticky and need replacement. A weak contactor spring or sticky contacts could also have this symptom if the current for the blower motor provides sufficient make-force once it's on that the spring can't break the contact, in which case turning off the power would sometimes be necessary to get it to release.
  1. Oversized furnace?
    By pitteach in forum HVAC Heating & Cooling
    Last Post: 07-09-2009, 08:19 AM
  2. Oil furnace in closet
    By griffy335 in forum HVAC Heating & Cooling
    Last Post: 10-19-2008, 07:25 AM
  3. Cleanout problems solved, now come vent problems
    By abrahuang in forum Plumbing Forum Discussion & Blog
    Last Post: 10-09-2007, 08:06 PM
  4. What furnace should we get?
    By Sincraft in forum HVAC Heating & Cooling
    Last Post: 09-02-2007, 01:13 PM
  5. oil furnace problems
    By crossthreaded in forum HVAC Heating & Cooling
    Last Post: 03-06-2007, 02:28 PM
