Thread: Seeking any advice on bad smell, PLEASE HELP!!!
    DIY Junior Member Hailo's Avatar
    Oct 2010
    New Orleans, LA
    Default Seeking any advice on bad smell, PLEASE HELP!!!
    This problem started about 3 years ago. I would get this foul odor while taking a shower. The toilet would not flush right. I called 3 different plumbers to check and fix the problem, but it keeps coming back. The last plumber ran a video thru the main line and used the *auger?* to clear the line. That worked for a year and it was wonderful. But now the horrible smell is back, the toilet is having a hard time just flushing water. Is there anything I can do??? PLEASE HELP MEEEEEEEEEE!
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    If you know the diameter and length of the main line you can check the flow rate and compare it with the expected value. In principle, at least.
    Jan 2008
    The drain and vent system needs to be inspected. You could have a clogged vent or no vent where there should be one.
    If the drain is clogging, it could be that it is not pitched properly. A plumber can send a camera down the line to inspect it for bellies, breaks, roots, etc.
    Cacher_chick has the the best advice. Assuming (a dangerous thing to do) your plumber ran the auger all the way through the drain to the sewer main, it would indicate one of the possible problems listed exists. A camera inspection would be a wise next step. By all means do not use chemicals. They are dangerous and do not work anyway.
  1. (another) Seeking bathtub choice advice (thread)
    By Ptron in forum Shower & bathtub Forum & Blog
    Last Post: 07-28-2010, 12:38 PM
  2. Landlord seeking advice on new water tank
    By Sheridanman in forum Water Heater Forum, Tanks
    Last Post: 12-11-2009, 01:51 PM
  3. seeking advice - Saniflo Macerating Toilet
    By meaw in forum Toilet Forum discussions
    Last Post: 04-21-2008, 07:49 AM
  4. Seeking shallow well pump debug advice.
    By bugs11 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-25-2007, 01:09 PM
  5. Seeking advice on installing a natural gas grill
    By elamcup in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-02-2005, 04:11 PM
