Huronshore
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I recently moved my pump (goulds 1/2 horse convertible shallow well jet w/ single intake/ single output lines (two total), and added a new bladder tank, placing an intermediate pressure tank between the pump and the bladder tank. The idea of the intermediate tank is to bleed off methane gas entrained in the water in this area . This tank is topped w/ an Amtrol auto-vent valve 700-c. Water comes in high on this tank and is drawn off low to the bladder tank. (Also have another same valve on the output side of the pump) I seem to have eliminated the gas, but I've been having trouble coming to 40 lbs (20/40 system), and I'm drawing air. Re-did my connections on the intake side, tightened, got some improvement today, but after the pump runs I can always let air out of the vent on the intake side. Also, the pump will sometimes come up to its pressure setting, (I've adjusted the cut-out to about 35 so it will shut off) shut off, then the pressure will drop upon shut-off to 20 or so, re-start, zoom back to max, shut off. (all in seconds) Sometimes this takes two or three "trys" to stay shut off, other times it just cuts out at 35 and holds. I'm at a loss to explain what's going on here, though I'm beginning to think that perhaps my draw level has dropped below my intake point a little, fills in but not fast enough, but I'm wide open to any ideas. (New pressure switch; added a water softener to the system when I did all this - not sure how much of this info is germaine to the situation, but I'm trying to be complete!)
