Results 1 to 4 of 4
Thread: how many lights in a circuit as per code
    DIY Junior Member pedrito's Avatar
    Sep 2010
    Canada
    Default how many lights in a circuit as per code
    It is my intention to place 24 pot lights around
    the perimeter of the house.
    24 lights of 50 watts, having of total of 1200
    watts.
    1200 watts divided by 120 volts gives me 10 amps.
    I have placed a new breaker of 15 amps. Wich lead
    me to think that I will be OK.
    The question that I have is: How many lights I am
    allowed asper code in one circuit.
    IT is 12 lights ONLY????
    PLEASE REPLY..thanks
    Sep 2009
    Seattle. WA
    It would really make no sense to have a limitation on the number of luminaires on a circuit, in the absence of
    any information on the power consumed per fixture. I have never encountered such a code limitation, and doubt
    that any such exists.
    DIY Senior Member thassler's Avatar
    Dec 2006
    Tennessee
    To calculate your total fixture wattage, you need to go by the mfg's max bulb wattage for that fixture. (i.e. I you are using 50watt bulbs but the fixture is rated for using 75 watt bulbs you need to use the 75watt figure to calculate with.) That said, I always try to stay within 80% or less of the circuit rating.(appox 1440 watts for a 15amp circuit)
    TreyH
    ** Not a professional - only a DIYr **
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    As I have read on other forums about the CEC, 12 is the max.
    You need to ask someone in the code or building office where you live!
    Yes I am A Pirate-Jimmy Buffett
  1. Residential Lights and Outlets on Same Circuit?
    By TomBrooklyn in forum Electrical Forum discussion & Blog
    Last Post: 08-24-2010, 08:08 AM
  2. NC Electrical Code - 20A GFCI Circuit in bathroom
    By WalterHego in forum Electrical Forum discussion & Blog
    Last Post: 12-21-2009, 11:12 AM
  3. lights on GFI protected circuit
    By pmayer in forum Electrical Forum discussion & Blog
    Last Post: 11-02-2009, 08:40 AM
  4. Number of lights allowed on a circuit
    By nashkato in forum Electrical Forum discussion & Blog
    Last Post: 05-01-2009, 07:37 AM
  5. AFCI Circuit trips when I turn on lights
    By Keith Wolf Ent in forum Electrical Forum discussion & Blog
    Last Post: 06-23-2008, 08:15 AM
