Results 1 to 13 of 13
Thread: Need help Removing Stem Glacier Bay Faucet
    DIY Junior Member raj49's Avatar
    Oct 2010
    MichIgan
    Default Need help Removing Stem Glacier Bay Faucet
    I have a Glacier Bay # 728-075 faucet thats leaking. I believe its Exclusive to Home Depot. After I removed the tip, I did'nt see a set screw or any retaining screw so I can remove the handle in order to access the stem and replace the seats, spring or stem.
    How do you disassemble these?
    Any help appreciated!
    Theres no set screw or anything in there I can pry further:
    The barrel shaped section under the lever unscrews. originally was put on hand tight, but you might need a strap wrench to not scratch the chrome.
    It MAY be Glacier Bay, but it looks like a knockoff of a Moen Monticello, and if so the big "barrel" unscrews from the faucet and the handle comes up with it.
    Oct 2010
    MichIgan
    So the Bigger bottom part unscrews or the part right under the lever I unscrewed?
    Here is the breakdown for the Moen Monticello which GB copied: http://www.moen.com/shared/pdf/ca84437pt.pdf
    Oct 2010
    MichIgan
    Sorry I need more help. Im kinda slow.
    Found this: http://www.terrylove.com/forums/show...-handle-faucet He had similar problem.
    So can I just turn the handle counterclockwise and it should come off or will the stem break?
    Oct 2010
    MichIgan
    Ok found this: http://www.moen.com/consumer-support...al?id=moen0132
    Gotta hold the handle.
    The HANDLE does not turn, only the "bulging" part under it. if you try to turn the handle, you will break something.
    Oct 2010
    MichIgan
    Ok so this isnt Moen but Glacier Bay. The bulging barrel part turns with the handle during normal use so Im not sure about this one.
    It should NOT . Yours is stuck. Need to hold the lever, turn the bulge without rotating the lever.
    Glacier Bay tech support 1-888-328-2373
    If it does not come off that way, then the only other way would be if it had small Allen screws somewhere, and it would usually be below the handle so they did not have to make two different handles. Yours does NOT show these. Good luck with "tech support", I once ordered a faucet diverter and got two stems.l
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    The handle just pulls off, try rocking it back and forth while pulling up. There will be a screw underneath holding a plastic adapter on the stem.
    In the Trades ilya's Avatar
    Dec 2009
    Akron Ohio
    GB's tech support leaves much to be desired. I once spent 32 minutes with them before they understood that the cartridge was faulty. It took two months to get the replacement. I reccomend my clients stay away from GarBage.
    not a licensed plumber
  1. Glacier Bay Glacier Bay Dual Flush HET AIO Toilet
    By bighornram in forum Toilet Forum discussions
    Last Post: 05-07-2013, 06:37 AM
  2. Strange problem with Glacier Bay Kitchen faucet
    By juriggs in forum Plumbing Forum Discussion & Blog
    Last Post: 04-06-2013, 11:46 AM
  3. Does shower faucet stem packing nut need to be removed before removing the stem ?
    By carlegeo in forum Plumbing Forum Discussion & Blog
    Last Post: 12-29-2012, 07:04 AM
  4. Glacier Bay lav faucet
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 03-27-2009, 02:54 PM
  5. Removing and replacing tub faucet stem
    By jono in forum Shower & bathtub Forum & Blog
    Last Post: 10-07-2005, 11:22 AM
