Results 1 to 5 of 5
Thread: Leaking p-trap joint and canít unscrew nut
    Default Leaking p-trap joint and canít unscrew nut
    I replaced my kitchen sink and garbage disposer and intended on swiveling the p-trap to line up with the new disposer. I thought the p-trap was attached with a slip joint connection and all I would have to do is loosen the slip joint nut. However, the nut wonít move. I was still able to swivel the trap slightly, and of course now there is a drip coming from that joint. Any recommendations on how to fix? Thanks.
    Name:  leaking joint.jpg
    IT is a "union nut" not a "slip joint" and they are often very difficult to loosen, and often when you do the nut cracks. Since it is a union joint, "moving" it does make it leak unless you can tighten the nut further, or take it apart and use a suitable joint compound on it.
    Thanks for the clarification. Since I donít think it can get any tighter, should my next step be to try turning the union nut (counterclockwise?) with Channel-Locks until it either comes loose or something breaks, and then go from there?
    Plumber jimbo's Avatar
    The nut is captive on the U, so the male threads are on the wall elbow. Make sure you are turning the right direction.
    You can try it, but I would just cut it off and redo the whole thing using tubular trap and fittings instead of sch. 40 glued ones.
  1. Slip Joint vs Threaded.....J Trap
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2010, 09:37 AM
  2. Leaking joint
    By nhoratiu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2009, 08:03 PM
  3. leaking joint?
    By bsperr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2009, 09:59 AM
  4. Leaking swivel joint on chrome trap
    By King3244 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-22-2006, 06:02 PM
  5. Leaking PVC Joint/Elbow/'T'(Y???)
    By Neonred in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-16-2005, 07:43 AM
