Results 1 to 8 of 8
Thread: No-hub Coupler Question/Advice for Sanitary Tee
    DIY Junior Member autostadt's Avatar
    Sep 2010
    Maryland
    Default No-hub Coupler Question/Advice for Sanitary Tee
    I need to splice a 3" sanitary tee off of a 3" vertical DWV in my basement. My question is do I glue stubs to the ends of the tee first since they flange out and then use the coupler to attach? I have no room to push the pipe out or up and this is why I have to use couplers. Or, is there another tee that would be more appropriate in this application? Thanks.
    If you use a plastic santee, normally you would glue pipe on the ends so that you have something to couple to.
    You could also use a cast iron no-hub santee and couple right to the fitting.
    Sep 2010
    Maryland
    Thumbs up
    Thanks Terry for the quick feedback! I think I'll go the PVC route. I assume "santee" is the lingo for sanitary tee?
    Dec 2007
    Yes sani tee is the lingo.
    Many times even with no room to move you can cement one side and use a shielded coupling on the other.
    Use a street tee so you only have to put a stub into the top end.
    Sep 2010
    Maryland
    THanks for the additional suggestions. I had thought about glueing one end and coupling the other - I will try if there is room. This is for a water softener drain and while I have seen the saddle tee's I assumed it would be best to avoid that method.
    Jan 2006
    Rosedale, Md
    Quote Originally Posted by autostadt View Post
    I hope you don't plan to hook this up solid without a trap?
    You do not have a washing machine drain anywhere in the area?
  1. PVC coupler
    By scott99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2010, 07:24 PM
  2. Question about Tub/Shower vent and WYE versus Sanitary TEE
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-25-2009, 05:50 AM
  3. DWV Sanitary Tee question
    By baldmagicguy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2008, 06:37 PM
  4. Advice for moving sanitary tee up
    By wrkane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2008, 02:57 PM
  5. Main Sanitary Stack Code Question
    By seaneys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2007, 10:24 PM
