Results 1 to 5 of 5
Thread: Water Hammer Arrester - Must be Vertical?
    DIY Junior Member larrymcg's Avatar
    Dec 2009
    Silicon Valley
    Question Water Hammer Arrester - Must be Vertical?
    I'm guessing this is a silly question, but..... Does the tube of a water arrester have to be vertical?
    Since the arrester tube has a piston that separates the water from the contained gas, I thought there could be a chance that the tube could be horizontal.
    I want to put arresters on the hot and cold lines to the clothes washer but the current flexible lines connect to shut-off valves with outlets that go straight down. So connecting something like the Sioux Chief Min-Restor at the shut-off valves would have the tube in the horizontal direction.
    --Larry
    They can be horizontal.
    However, you can also mount them on the washer and keep them vertical is you want.
    Dec 2009
    Silicon Valley
    I wonder why I didn't think of mounting them on the washer? The connections on the washer are above each other so I could mount the top arrester vertically and the bottom one at a slight angle to miss the top one!
    Larry
    Ideally, the arrester is installed as close to the quick-acting valve as possible...and, with an engineered on, orientation is irrelelvant.
    Point the top one up and the lower one down. They will work effectively in either direction.
  1. hammer arrester
    By jetlag in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2010, 09:54 PM
  2. Water Hammer Arrester Needed
    By Mike50 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-30-2009, 02:32 PM
  3. Moving Water Meter from Horizontal to Vertical Position
    By jluksic in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-12-2008, 09:44 PM
  4. Choosing a water hammer arrester
    By lahabra in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2008, 11:08 AM
  5. Demo Hammer/Roto Hammer--Help me choose
    By rshackleford in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2007, 05:34 PM
