Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: 50A receptacle on 40A circuit okay?
  1. #16
    Plumber jimbo's Avatar
    Just remember.....anything you say after hj has the last word, starts a new thread completely!
  2. #17
    Feb 2005
    Omaha, NE
    Quote Originally Posted by Ian Gills View Post
    You did not say that. You said you could put any receptacle you want on a circuit as long as the breaker and the wire are sized correctly.
    You could not put a single 15 amp receptacle on a 20 amp circuit, for example. At least I wouldn't.
    Common sense.
    I realize this is quite correct as far as the NEC, but the logic of it escapes me.
    I don't see how a 15-amp receptacle on a 20-amp circuit is a safety hazard. What am I missing?
  3. #18
    Most receptacles can pass through more current than they can source at an individual outlet and Ian is wrong...you can use 15A devices on a 20A circuit. Although, if you have some one thing that can monopolize the circuit's max current, it's sort of nice to size the outlet for that user.
  4. #19
    DIY Member Artie's Avatar
    Nov 2009
    Jacksonville, Fl
    For what its worth, twice a year, (Thanksgiving and Christmas), pretty much every burner on the cooktop, and both ovens of the double oven, are going full speed.
  5. #20
    IN THEORY....a 15 amp equipment could have an internal fault, and since the breaker wouldn't pop until 20, damage or overheating could occur since internally, the equipment is designed to be protected by 15 amps max. This is a stretch of an argument, and the NEC apparently feels comfortable enough to allow it. I do understand that the Canadian Electrical code does NOT allow it.
  6. #21
    Jun 2007
    North Carolina
    Quote Originally Posted by SteveW View Post
    As long as there are more than one receptacle then 15 amp devices on a 20 amp circuit is permissible per the NEC. Look at the receptacles in your ktchen and bath
  7. #22
    Electrical Contractor Bobelectric's Avatar
    Feb 2009
    Eighty Four,Pa. 15330
    I make the extra step and "pig Tail "all my receptacles rather than feed through.
  8. #23
    Jul 2007
    USA
    Good for you. That's good work.
  1. Convert 220 circuit to 110 circuit to be run to new subpanel
    By C Willard in forum Electrical Forum discussion & Blog
    Last Post: 10-24-2009, 06:39 PM
  2. Single receptacle to a double receptacle
    By beeger11 in forum Electrical Forum discussion & Blog
    Last Post: 05-02-2009, 06:01 PM
  3. Changing receptacle
    By tlong_66 in forum Electrical Forum discussion & Blog
    Last Post: 04-09-2008, 07:16 PM
  4. How to tap off a receptacle
    By jar546 in forum Electrical Forum discussion & Blog
    Last Post: 02-26-2008, 07:03 PM
  5. Receptacle question
    By Nate R in forum Electrical Forum discussion & Blog
    Last Post: 02-12-2008, 04:30 PM
