Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Splicing into 3" PVC horizontal drain line
    DIY Junior Member PharmD's Avatar
    Sep 2010
    Boston MA
    Default Splicing into 3" PVC horizontal drain line
    Hi, just a quick question on what would be the most appropriate way to splice into an existing horizontal 3" PVC waste/drain line in my basement. I need to replace a 3"X3"X1.5" wye with a 3"X3"X2" wye (this is for the washer) There is no left or right movement to allow the new wye to slide in and be cemented. Should I use: two 3" PVC repair/slip couplings, 2 ferncos, or two banded couplings? Thanks for the help.
    Dec 2007
    Depending on movement allowed I would have a 1st choice of a regular pvc coupling and a shielded coupling or, a 2nd choice of 2 shielded couplings.
    Put the band on the pipe sliding it up the pipe out of the way, then put the rubber in place and roll it back over itself, put the pipe in place, roll the rubber back into place over the pipe, then put the band in place and tighten it.
    Dec 2009
    northfork, california
    I really have to wonder why plumbers have not discovered what goes on in irrigation
    pipes yet: Clamp and glue on saddle tees and y's.
    hole saw a hole in the pipe, file it and glue and clamp on the tee. About 1/8 the time spent and better than rubber rolling and grunting around trying to make it work.
    Maybe it has something to do with getting paid by the hour, unlike a farmer????
    quote;
    We have known about saddles since the day they were invented. So have the plumbing codes and they ALL say saddles are PROHIBITED. I have never found any farmer who did not think he was an expert in EVERYTHING, which is why my dad said he almost starved to death when we lived in a farming area. That and having to take everything from a plow, to a manure spreader, to a goat in payment for work that he DID do. It took a long time before I realized why the meat locker was filled at the same time my goat "ran away".
    Dec 2009
    I was talking about todays farmers. Old day farmers did'nt have PVC irrigation pipe and sprinklers, and miles of mainline, that if each 2" off shoot from a 8" mainline required a reducing tee, for perhaps 45$, they would be broke like in the old days.
    Saddle tees are strong, reliable, and easily installed. It is an artifact of ignorance if they are not allowed into the code.
    My kids eating a chicken right now that also "ran away". You had a bright dad.
    And by the way, I mean PVC saddle tees that get sanded, primed and glued and clamped with SS clamps. Better than any piece of rubber hose in my book, wrapped in SS or not.
    Dec 2007
    Quote Originally Posted by ballvalve View Post
    Perhaps the reason they remain prohibited by code is they routinely fail in applications where they are allowed. Hence due to their unreliability they remain an illegal connection...
    To have a little extra water leak out in a farmers field is one thing....
    A few rows of crop washed out...
    A little extra soil in the runoff...
    The liability inside a home is quite a bit more and less easy to fix than pushing some dirt around in a field...
    We'll stick with abiding by our "Artifact of Ignorance" and if it is ever changed then we may or, may not decide to use them.
    Even then it will be our choice whether we meet or, exceed the code specifications.
    Dec 2009
    If you mean a pressure pipe saddle tee, with a rubber washer, indeed they fail.
    Someone or some agency you know tested pvc glue-clamp saddle tees on DVW? I would like to see that report.
    What are the applications [non pressure] that you have used them in where they have failed, and in what manner?
    Jul 2007
    USA
    I thought all Americans were farmers?
    Now I'm confused.
    Dec 2007
    Lateral connections to city sewer, roof drains...
    I didn't use them...
    I fixed them!
    George the Plumber Gsalet's Avatar
    Sep 2010
    San Francisco
    I agree two banded coupling is the way to go, Saddles are for amateurs
    Dec 2009
    An amatuer would not know what a saddle tee was if it fell on him.
    So they must be made for sleazy pro's or very bright problem solvers.
    Some of these saddles are very highly engineered and as strong as a normal fitting.
    I found some old threads from here that tell me plumbers all hate them and engineers seem to love them.
    DIY guy with a saddle tee and about 15 minutes = 15$ Plumber with a few banded couplings, fighting pipe in a tight wall= $400. Thats a lot of food money in this depression.
    DIY Member Hillbilly Man's Avatar
    Nov 2008
    Wee-Todd-Id Valley, North Carolina
    Ar yu an enginear? Yu shur talk lik one.
    Wun ah my kinfolk was an wuz an enginear.
    He wuz a fart smeller but twuz all book learnt an he din't ave a lick o common sense.
    Ez been all laid off now fer a good long time an he'z been buyin up my shine fer a a good long whyle...
    I do say iffen he killz offa few mora them enginear brain cellz he might start gittin smarter.
    Hillbilly Eng-in-ear
    Moonshine Maker
    Dumb as a Stump
    In the Trades Wally Hays's Avatar
    Nov 2009
    You know the thread has gone south when Hillbilly gets a yearning to post
    Perception is 3/4 of reality
    Dec 2007
    Quote Originally Posted by Wally Hays View Post
    Yes it sure is...
    I think he does have a bit of wisdom to share though...
    I bet his moonshine operation is up to code and first class with the exception of taxes...
    Dec 2009
    Bet his still has saddle tees all over it.
  1. 3" or 4" PVC for Sump Discharge Exterior Drain Line?
    By dwt in forum Plumbing Forum Discussion & Blog
    Last Post: 07-13-2009, 07:17 AM
  2. Quick ? re PVC-Kerdi drain splicing through concrete
    By jordanski in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2007, 01:02 PM
  3. Splicing into existing 3" PVC sewer line
    By Niles in forum Plumbing Forum Discussion & Blog
    Last Post: 11-29-2006, 07:50 PM
  4. splicing in a new drain
    By jasonb in forum Plumbing Forum Discussion & Blog
    Last Post: 11-28-2006, 05:50 PM
  5. Bends in horizontal drain line
    By Mikey in forum Plumbing Forum Discussion & Blog
    Last Post: 11-10-2005, 02:09 PM
