Mainline Repair Still Leaks
Kiko
Royal Oak, Michigan
The main line of my parents' sprinkler system was ruptured by their landscaper. It is a 1" black poly tube. I cut off the bad portion and clamped on a 1" hose connector using 2 worm gear clamps. I kept the line straight when repairing this and tightened down the clamps as much as I can, but the repair still leaks a bit. If this was on a zone, I wouldn't care, but since it is on the main line, it is always pressurized.
Do I have any other options for repairing this? I know they make compression fittings for PVC/PEX and shark fittings, but I don't think they work on the thinner walled poly pipe. Or do they? They also sell crimp-on clamps, but I didn't want to buy the expensive crimper, and not sure if those clamps will seal any better.
Black Poly?
You can buy new poly, fittings and hose clamps. You just need to replace whatever is leaking.
It normally goes back together real nicely.
