Results 1 to 9 of 9
Thread: I see a lot of posts on here about AAV's failing, but how many times have you actuall
    DIY Junior Member
    Jan 2010
    Southeast
    Default I see a lot of posts on here about AAV's failing, but how many times have you actuall
    I see a lot of posts on here about AAV's failing, but how many times have you actually experienced one failing?
    What percentage of the time (installations) have you seen them fail or have direct knowledge of one failing? 50%? 25%? 10%? 1%?
    Nov 2005
    anecdotal evidence is what you are asking for. Like asking how many people you know personally who got electrocuted. After all, it doesn't really happen very often now, does it? Sewer gases can be undetected by the human nose, and can kill you. If you ask how many people really have died from sewer gases, you would find it happens every year.
    Dec 2009
    northfork, california
    If its a top quality rubber, or composite with a good SS spring, I'll bet they last the life of the fixture or room until the next remodel. Approved use of them would save millions in roof holes and materials wasted.
    Unless you sleep inside your island cabinet, I doubt anyone will ever die from a bad one.
    I've experienced a bad AAV before, that bathroom smelled pretty bad.
    So yes, like "any" mechanical device, it does happen.
    You know the rubber flappers in toilets? Those get replaced.
    When a homeowner has a smelly bathroom or kitchen, do they have enough knowledge to trouble shoot the problem? No. Not really, so when these problems do occur, they aren't reported or repaired.
    The reason plumbers like a "real" vent in the wall and up through the roof, is that they don't need to be "fixed". They are pretty much install and forget.
    Not that AAV's don't have their place, but for the same money in parts, and an insignificant amount of installation time, it makes way more sense to run a solid vent.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    AAVs are no substitute for a proper open vent. And don't forget, sometimes the best way to snake a line is through the roof vent...having AAVs everywhere would eliminate that option, and require ugly access panels everywhere!
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Jun 2009
    Canada
    Yeah, you might as well install something with a spring and some rubber rather than an open ended pipe through a roof... Give your head a shake, it's obvious which is the better solution.
    DIY Junior Member aavguy's Avatar
    Sep 2010
    Pittsburgh, PA
    Quote Originally Posted by geniescience View Post
    Aren't sewer gases typically pretty strong smelling? I bought one of these First Alert alarms that detects methane gas because I am paranoid.. anyone know if these work well?
    Never heard of one detecting sewer gas. The problem with them is that they can go bad, but no one knows about it for a long time.
    Plumber jimbo's Avatar
    Nope...can't say I have seen a bad one. The problem that worries me is , they are often installed below the flood rim, so on occasion if there is a bad backup, that rubber seal area is vulnerable to being fouled. Who know what happens the next time?
    I would say they have become a fact of life, and just one more thing to deal with.
  1. Toto Aquia dual flush toilet product review, comments and posts.
    By stimpsonjcatt in forum Toilet Forum discussions
    Last Post: 01-27-2014, 09:32 AM
  2. Does the NSPC allow AAV's ?
    By Rich B in forum NSPC Plumbing Code Questions
    Last Post: 07-23-2010, 07:19 AM
  3. improving quality of my posts
    By ilya in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2009, 05:47 PM
  4. Attaching 4x4 posts to concrete
    By little buddy in forum Remodel Forum & Blog
    Last Post: 11-14-2008, 11:41 PM
  5. Terry's Drawings in posts and other books
    By construct30 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-29-2007, 05:51 PM
