Results 1 to 7 of 7
Thread: seems like the water heater connections are rusting after 1 month..is this normal?
    DIY Junior Member dooo42's Avatar
    Sep 2010
    ri
    Default seems like the water heater connections are rusting after 1 month..is this normal?
    on 8/16/2010 i had a tankless rinnai water heater installed by my gas company and it seems that some of the pipe connections, in and outside of the house look like they are rusting. is this suppose to happen? should i have the gas company look at it.
    thanks
    Are the things rusting black iron pipe? If so, first, that may not be the best thing for outside, and second, if it is allowed needs to be painted, or like any iron, will rust.
    Sep 2010
    ri
    The outside pipe looks like it's black with gray paint on it but rust is coming through. the inside rust looks like it's occurring at connection points (these connection don't look black) between pipes and on pipe thread.
    Can you attach a picture, 800 pixels or less.?
    George the Plumber Gsalet's Avatar
    Sep 2010
    San Francisco
    What connections are rusting the water inlet and outlet or the gas connections? picture is worth a thousand words
    Sep 2010
    ri
    Default here are some pictures
    here is a picture of connection inside my house. i'll get more up for you to check out
    Sep 2010
    San Francisco
    Is this in a humid location? maybe a little oil or paint will slow it down
  1. piping connections to water heater
    By Steve_P in forum Plumbing Forum Discussion & Blog
    Last Post: 08-31-2010, 06:27 PM
  2. 2-3 month dle water heater; To drain or not to drain??
    By delta_v in forum Water Heater Forum, Tanks
    Last Post: 03-24-2010, 11:19 AM
  3. Is it normal to use this much water all at once?
    By Amy_2009 in forum Irrigation / Sprinkler Forum
    Last Post: 08-06-2009, 11:56 AM
  4. Water usage 100,000 gallons per month?!
    By TequilaMB in forum Plumbing Forum Discussion & Blog
    Last Post: 12-23-2008, 05:47 AM
  5. Hot Water heater Connections
    By pilotboat in forum Plumbing Forum Discussion & Blog
    Last Post: 02-07-2007, 07:15 PM
