Results 1 to 6 of 6
Thread: basement rough in
    DIY Junior Member robert8's Avatar
    Sep 2010
    Maryland
    Default basement rough in
    Hi,
    I am planing to finish my basement bathroom in a single house built 2 years ago in Maryland. I have some question about these pipe rough ins. The are 2 biger ones. one is black 5" and in 2 ft away is a 4 " white one. I guess the black one is for toilet. but what is the white one for? if for the shower drain, it is too close to the toilet and is just 2 food in front of the sink drain pipe. There are another two 2"pipes behighd the 2 bigger ones.. one with tee connection and connect to the first floor for vent, I guess this is for sink drain, and another one without Tee connection, I guess this is for tube drain. Also, How do I know there is or is not a P trap under the cement fo r the tube? Do I need connect any more vent for the tube or toilet?
    Many thanks
    Robert
    George the Plumber Gsalet's Avatar
    Sep 2010
    San Francisco
    Wow Talk about a stab in the dark!! I would open the capped 2" pipe and see if it has a trap under the slab. If it does it looks like a tub drain. If it doesn't I would guess vent for toilet. My best guess is the black pipe is a cleanout. But in till you open the pipe you will not Know. I suggest calling a plumber who has a video inspection camera to figure it out, Probably cheaper to have him finish the plumbing for you than making mistakes.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    The 2" stub coming out of the vent stack is for your lav, the 2" stub coming up from the slab is for your tub/shower drain, the 4" stub coming up from the slab is for your toilet, and the 5" black stub might possibly be a backwater valve. You better leave plenty of access to that pit ejector unit if you plan on finishing this yourself.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Sep 2010
    Maryland
    Quote Originally Posted by Basement_Lurker View Post
    Thanks, Basement-lurker,
    Do you suggest that I should install the backwater valve before or at the sametime when I finish the basement bathroom?
    There is a big stub (6" white pipe) with openable cap on the yard outside of the walk-out basement, looks like related to a sewer system, is that a backwater valve, too?
    Many thanks
    Robert
    Sep 2010
    Maryland
    Quote Originally Posted by Gsalet View Post
    Many thanks , Gsalet. Your answer is quite helpful.
    Do you mean the black pipe ,"a cleanout" is something that the Basement_Lurker mentioned backwater valve?
    Thanks again.
    Robert
    Sep 2010
    San Francisco
    I don't think it's a backwater valve but I could be wrong
  1. Basement Rough In
    By shamrock_94 in forum Shower & bathtub Forum & Blog
    Last Post: 07-13-2008, 02:27 PM
  2. Basement Rough In
    By jimdeprado in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2008, 07:56 PM
  3. Basement Tub Rough In
    By St. Joseph, MN in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2007, 08:39 PM
  4. Basement Rough-In
    By srk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-18-2005, 05:51 AM
  5. Basement rough-in
    By BillyD in forum Remodel Forum & Blog
    Last Post: 03-07-2005, 02:27 PM
