air in water lines, well and gas hot water heater
suemax
14712 NY
I have air in water lines. It seem to have happen after a gas AO Smith water heater was installed .
Inspektor Ludwig
Journeyman/Inspector
In the good ol' UPC
Is this a statement or a question? Are congratulations in order? What you have is normal and will go away. That cloudy looking water is just little tiny air bubbles and the banging and that comes from your faucet when you turn it on is just air finding it's way out, that will go away too.
suemax
14712 NY
"The air in water lines won't go away. It has occurred for several months. Thanks"
Nukeman
Nuclear Engineer
VA
I doubt it is related to the WH. You may have a leak on the suction side of your well pump and that is putting air into the system when the pump runs. What type of pump is it?
Cacher_Chick
Test, Don't Guess!
I agree that you probably have a leak, which is most likely in your well.
If you have a galvanized pressure tank, it is also possible that the problem is a faulty air volume control on the tank.
suemax
14712 NY
" How can I determine if my 140 gallon AO SMITH AQUA-AIR water system tank is defective and source of my air in my pipes? How can I determine if the well is the source of my air in the system? Either problem is an expensive fix. I would like to isolate the source of the problem so I can spend my money on the right fix! THANKS
Cacher_Chick
Test, Don't Guess!
There is no way for a pressure tank to create air.
If this problem has been going on for the time you mentioned, it is most likely a leak in the pipe that goes down to the submersible pump.
