Results 1 to 8 of 8
Thread: Two wires
    DIY Junior Member jc60618's Avatar
    Dec 2009
    Chicago
    Default Two wires
    I am replacing a ceiling fan, when I removed it I noticed no grounding wire just two wires which are the same color. Is there a way to find out which is the positive/hot wire?
    There should be a ground wire. Anyway, of the two internal leads, one should be "identified" meaning a white stripe, or ribs on it , or something. That is the neutral wire.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    If there is no ID on the wires from the box, run an incand. bulb from each wire, in turn, to a "known good ground". The hot wire will light the bulb.
    A meter may respond to Phantom Voltages and confuse you, unless you are using a type of rugged, solenoid voltmeter that electricians use that is called a Wiggy.
    Jul 2007
    USA
    Ah, the joys of 1950s wiring. All wires turn to black.
    There are many ways for US to determine which is the hot wire, but since we do NOT know what type of instruments you have, we cannot tell you how YOU can do it.
    Dec 2009
    Chicago
    Am a plumber, the only electrical equipment I own is a craftsman multi-meter. I did take electric shop in high school six years ago and do know how to run wires to complete a circuit. I was just surprised to see that the hot and neutral wires were the same color.
    Unless it is in conduit, there were NOT when they were installed. In conduit the colors could be whatever the installer had, if he decided not to follow the convention of using white for the neutral.
    Jun 2007
    North Carolina
    Quote Originally Posted by jc60618 View Post
    Find the cold negitive and the hot positive will be the ohter one.
  1. wires going in breaker box
    By geandham in forum Electrical Forum discussion & Blog
    Last Post: 10-28-2009, 08:47 AM
  2. Wires in electrical box
    By toolguy504 in forum Electrical Forum discussion & Blog
    Last Post: 07-31-2009, 05:12 PM
  3. How can I tell if my wires are live?
    By coopns in forum Electrical Forum discussion & Blog
    Last Post: 07-25-2009, 06:33 PM
  4. electrical wires near shower
    By edwardh1 in forum Plumbing Forum Discussion & Blog
    Last Post: 06-03-2009, 09:14 AM
  5. Speaker wires
    By Nate R in forum Electrical Forum discussion & Blog
    Last Post: 06-26-2008, 09:03 PM
