Results 1 to 6 of 6
Thread: All appliances are working properly but my outside pipe is overflowing!!!!
    DIY Junior Member zsduncan's Avatar
    Sep 2010
    California
    Default All appliances are working properly but my outside pipe is overflowing!!!!
    Hi my name is Zlata and I think I might be in some trouble here. There is no backup or overflowing inside my home but outside there is a pipe that overflows every time I take a shower or flush the toilet.
    I tried using the snake on the outside pipe but nothing came out. I got it in there about 15 feet and it came out with nothing.
    I dont have a septic tank and think I am on county water system.
    Please help there is waste overflowing!!!!
    There is a clog, and it could be much further away than the small snake you tried. A main line usually requires a pro to clean it out. It is not normal for it to overflow outside...normally, that pipe is sealed, so unless someone left a cap of, you may have a broken pipe (which could be the clog). Time for a pro, I think. Suggest you might avoid those with 'rooter' in the name.
    Sep 2010
    California
    Thats what I was thinking. I was hoping it might be something I could fix though. Thanks for your response.
    Dec 2007
    Yep You need a Plumber/Drain Cleaner to snake the line clear.
    You have a clogged main sewer line.
    This is not a DIY job. It will take a HD industrial sized auger to clear the drain and even if you could find one, you would literally risk your life trying to use it. These things require a trained person to use. As others noted, it is very likely the cause is a broken pipe since that is about the only way drain water would escape the drain pipe and not overflow in the house. Sorry, there's no quick, easy DIY band aid fix.
    quote; As others noted, it is very likely the cause is a broken pipe since that is about the only way drain water would escape the drain pipe and not overflow in the house.
    It is more likely a cleanout opening with a missing cap or plug. The reason everything inside the house is working is BECAUSE the water is escaping outdoors.
  1. how to get water out of copper pipe to solder it properly
    By dy in forum Shower & bathtub Forum & Blog
    Last Post: 03-02-2013, 08:59 PM
  2. PVC pipe outside of house keeps overflowing
    By BobtheBuilder1234 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2010, 11:56 AM
  3. Well overflowing around pipe
    By kdodds in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-20-2009, 01:29 PM
  4. working with poly pipe
    By ctrautma in forum Irrigation / Sprinkler Forum
    Last Post: 04-09-2008, 10:37 AM
  5. Drain pipe overflowing
    By sparkyrhett in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2007, 08:00 AM
