Two wires
Jc60618
DIY Junior Member
Chicago
I am replacing a ceiling fan, when I removed it I noticed no grounding wire just two wires which are the same color. Is there a way to find out which is the positive/hot wire?
Jimbo
San Diego, CA
There should be a ground wire. Anyway, of the two internal leads, one should be "identified" meaning a white stripe, or ribs on it , or something. That is the neutral wire.
Thatguy
Homeowner
MD
If there is no ID on the wires from the box, run an incand. bulb from each wire, in turn, to a "known good ground". The hot wire will light the bulb.
A meter may respond to Phantom Voltages and confuse you, unless you are using a type of rugged, solenoid voltmeter that electricians use that is called a Wiggy.
Ian Gills
Senior Robin Hood Guy
USA
Ah, the joys of 1950s wiring. All wires turn to black.
There are many ways for US to determine which is the hot wire, but since we do NOT know what type of instruments you have, we cannot tell you how YOU can do it.
Jc60618
DIY Junior Member
Chicago
Am a plumber, the only electrical equipment I own is a craftsman multi-meter. I did take electric shop in high school six years ago and do know how to run wires to complete a circuit. I was just surprised to see that the hot and neutral wires were the same color.
Unless it is in conduit, there were NOT when they were installed. In conduit the colors could be whatever the installer had, if he decided not to follow the convention of using white for the neutral.
JWelectric
North Carolina
Find the cold negitive and the hot positive will be the ohter one.
