Results 1 to 14 of 14
Thread: Flexible (roll) copper for bathroom supply lines?
    DIY Junior Member Flot's Avatar
    Sep 2010
    Florida
    Default Flexible (roll) copper for bathroom supply lines?
    Is flexible (roll) copper going to be a safe choice for supply lines to a bath?
    Quick situation: remodeling house, and have some limited attic access. Houses in the neighborhood (built in 1960-63) have started having copper pinhole leaks, fitting leaks, etc.
    I have an easy way to repipe most of the house before I hit those same issues. However I have one bath which is 50' away from the rest of the plumbing.
    I have not run across a local plumber that is confident in PEX. I would prefer not to use copper pipe or CPVC as that would leave me with 5-6 fittings inside my attic ceiling - attic is not accessible from above, but is accessible from below right now while i'm remodeling.
    One plumber has suggested flexible copper roll. Aside from the prohibitive cost of materials, I like the idea of a continuous run of pipe through the attic for leak resistance. Anything else I should be aware of with this approach?
    Jul 2007
    USA
    Use copper and trust the fittings.
    I trust the fittings I sweat myself more than the pipe.
    Do your best to protect it from freezing though.
    Consider putting in an access panel before you seal everything up.
    I use them a lot.
    There is no real problem with soft copper in rolls. If it is more expensive, then it is because the plumber is using a lighter grade copper for the "straight" runs with fittings.
    Sep 2010
    Florida
    Appreciate the reply - copper pipe is going to be very difficult in my attic - almost impossible to get rigid 10' sections up there, 20' sections would be completely out of the question.
    My big question is, is roll copper dramatically different than rigid copper? Is roll copper a "bad thing" or almost as good overall considering the install benefits?
    The only difference is one is hardened and the other is not. The major difference is that soft/rolled copper does NOT come in grade "M", which is much cheaper.
    Sep 2010
    Florida
    Thanks. My comment on cost was more of cost of copper (any type) vs plastic (any type).
    He threw out a number around $250 for a roll of 50' (I think 3/4") copper. Not sure I really need 3/4 although there is a hose bib on the outside wall of that bath where it would be nice to get the extra flow.
    If people are getting pinholes in their copper, why would you want to replace the existing with copper? Some places just have water that is nasty to metal pipes. Pex is also more tolerant to freezing, but any pipe run in an attic should be on the ceiling side of the insulation. If you wanted, you could conver to copper in the walls.
    Sep 2010
    Florida
    Copper is lasting 50 years in my neighborhood which is fine by me. No freezing issues here in south Florida. Biggest worry might be heat gain from attic but I think I could live with that, our "cold" water is 80 degrees anyway.
    Jun 2009
    Canada
    Quote Originally Posted by Flot View Post
    You don't honestly plan on not having a hatch to get into the attic later on, do you?
    Sep 2010
    Florida
    I "upgraded" from one access hatch to 3 hatches. There is still ~50% of the attic that is effectively impossible to access. At its highest point there is about 2' of room in the attic. Add in 12" A/C ducting, plumbing, conduit, etc - and it's very difficult to do anything. That's why I prefer to have as much of a continuous run of pipe as possible, any leaks will only be detected/fixed by ripping out the ceiling.
    to get pinholes, you're drinking copper since your water is disolving it.
    Plumbing copper does NOT come in 50' rolls. It is either 60' or 100'. The only copper that comes in 50' rolls is ACR refrigeration tubing and that is too thin to use for plumbing.
    Sep 2010
    Florida
    I can't seem to find a lot of information on the differences, in fact a couple of websites reference refrigeration copper and plumbing copper being the same thing, with the exception that one is measured ID and one OD. Another said refrigeration grade was thicker/better than 'plumbing grade.'
    What would I be looking for in terms of marking on the pipe? (it's already a done deal, came this AM and installed when I couldn't be home)
    I.d. is nominal and o.d. is actual. ACR tubing is about equal to type "M" plumbing copper, the difference being that it is in a 50' roll rather than 20 straight lengths.
  1. Flexible supply lines on a gas water heater
    By Ian Gills in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-26-2010, 08:51 PM
  2. Do you pros use flexible supply lines? Any tips?
    By SteveW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2009, 03:37 AM
  3. Can I use flexible supply lines from shuttoffs to shower valve?
    By Jhawk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-10-2006, 06:24 AM
  4. Do I need a flexible copper fitting where these lines connect
    By templar2b1ask1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2005, 12:11 PM
  5. How durable are flexible supply lines?
    Last Post: 04-16-2005, 06:28 AM
